centralsweeper63
You incorrectly used a Kirby many times in that link. That is not "scientific evidence".
Sounds like a SEBO or Henry would be right up your ally.I really couldn't care less if my vacuum is the newest model, or even a nice colour. I just care about reliability, as in that it will turn on and work every day when I need it for 30 or more years. Even if a vacuum only removes a majority of the dirt in the carpet it will eventually, if used every day or two, clean pretty much ALL the dirt from the carpet.
Interesting take, or now are 'you' redefining the word "you?"I've clarified that post you cited twice was directed at an external source. And RE the first two sentences: no. That was clearly observed and not an insult. That you interpreted a statement of an observation as an insult in fact is highly revealing about the situation. And I agree with you: it doesn't look good when someone mocks and rejects an educational opportunity.
You have failed to provide a single example of a personally directed insult to another member as you claimed. I don't think you understand what an insult is and are showing severe hypersensitivity in lieu of an argument or position, or falling victim to assuming criticism of an idea is the same as criticism of the person who holds the idea. Let me give you some examples of what directed insults of the nature you're struggling to evidence actually look like: 1, 2. I guess you're OK with them, though.
to prove the definition of the word 'you?'statistically significant data
OK, too vague to comment so I'll ignore that one.
a) This is a failure of understanding. The user lacks the knowledge and seemingly the intelligence that with strong suction on high resistance carpets, head pressure drops, increasing clamping force. The solution is to directly reduce suction pressure by lowering the motor power, or to allow in bleed relief air (more airflow) via the gates to reduce suction pressure to nearer normal levels. As explained in the lecture, this also doesn't impair cleaning performance. So this was a demonstration of incredible ignorance more than anything.
b) Again, user stupidity. If you're dumb enough to put so much dirt down that it's clearly visible to the naked eye and then briefly go over it once—even lifting it off the floor surreptitiously on the backwards pull in a dodgy manner you'd only expect the most repulsive charlatans to, it's not surprising it left stuff behind. This was a wonderful example of the kind of BS I criticise out there. Poor testing, deeply flawed, unquantified, doesn't capture trends, easy to trick people, unconvincing to the educated and intelligent.
If this is what you're using to justify I'm in the wrong somehow, then that's wonderful for us all to see, since it clearly exonerates me from a false charge. Thanks for the future reference link at least.
Perhaps this clarification will help you understand something many others have likely appreciated by now, if not from the initial comment about an external video posted.May I remind 'you' (again...) that 'you' asked 'me' for the specifics in 'your' preceding post, so "I" provided them to 'you.'
Pity you didn't evidence how in an objective and convincing manner. Instead, you simply decreed by fiat. This further damages the credibility of future output.You incorrectly used a Kirby many times in that link. That is not "scientific evidence".
Aha, so you misspoke (mistyped) when you used that pesky little word "you're?"Perhaps this clarification will help you understand something many others have likely appreciated by now, if not from the initial comment about an external video posted.
"This is a failure of understanding [by the person in the YT video]. The user [of the machine in the video] lacks the knowledge and seemingly the intelligence..."
If you remain confused at this stage, I'll assume you've no intention of understand, are just troublemaking, and give no further attention.
Pity you didn't evidence in an objective and convincing manner how the V15 was being used incorrectly. Instead, you simply insulted and decreed by fiat.Pity you didn't evidence how in an objective and convincing manner. Instead, you simply decreed by fiat. This further damages the credibility of future output.
