The hack that can save pre-release version of Dyson V16
Absolute Rainbow
Vietnam
@shattered @Vacuum Facts
As @Vacuum Facts has tested and noticed, the preliminary release of Dyson V16 has utterly pitiful performance, Auto mode actually worse than even Dreame Z30 and the overall performance dropped to about half of that of Gen5. This is due to the Hyperdymium 900 W motor operating at mere 450 W. No, really, but there's a hack that actually fix that motor sensitivity and let the motor unleash itself, so the vacuum can perform as admirably as it's supposed to be (i.e. at least on the level of Gen5).
Can you tell us what's the hack that fix the pre-release V16 and turn it back into a true main-equivalent it's supposed to be?
The reason I'm not discussing any of this is because most of the 'major reviewers' haven't reviewed it yet and I don't want any of them copying off me. They'll have to figure it out themselves from the basic science available. I'm posting my review last this time.
The best thing people can do for now is complain to Dyson it doesn't clean as well.
Unfortunately, community.dyson.com is completely offline. No choice but to bring the matter to social media - oh wait, you're currently putting your review on hold!
Maybe Dyson did that cause otherwise you wouldn't be able to push it on carpets
It wasn't that long ago that you could buy a 2200 watt canister vacuum in Europe and people didn't have any problems pushing the nozzles of those on rugs or carpets. In Japan you can buy insanely powerful corded power nozzle canister vacuums that are easy to push on rugs and carpets. They have openings to let some air in under the nose of the nozzle so they don't latch. My hardworking old Panasonic MC-PA20W converted to use a modern G series power nozzle will lift a bathroom rug off the floor if I lift the nozzle straight up but I can push it along effortlessly.
@Vacuum Facts did Dyson deliberately make the mistake to reduce clamping and increase battery life? Either way, that ultimately explains why the V16 performed so poorly out of the box, at least in its debut.
The rest of the V16 however is amazing, I just need @Vacuum Facts to tell us the hack that fixes the machine. This is scummy on Dyson's part.
Exactly and thats the thing! Wheres the point in having a 2000W when you can't even use it and have to create openings in head to lose suction/power?
Isn't it a bit of a waste?
Maybe try using one and find out. If you have never used these kinds of vacuums you have no basis of comparison with which to make an informed opinion.
Fact is power nozzles have been latching onto carpets from the very beginning. The very first power nozzle from Lewyt way back in 1957 has that problem on a much less powerful vacuum. They had to add wheels on the nose of the power nozzle so it didn't latch. Old Filter Queens and Eurekas had that problem too and the solution was to drill a line of 3/16 inch holes along the nose of the nozzle base to let a little air underneath. These were 8 to 9 amp vacuum with old fashioned motors. Nothing like you find on a modern corded power nozzle. I have this equipment in my collection and use it. How about you? What is your experience with these older vacuums?
Around 2015 or so Panasonic came out with a power nozzle for use by Kenmore and Cen-Tec central vacuums that has an air bypass system. There are reed valves behind vents on the top of the nozzle. If it starts to latch, the reeds open and let some outside air get under the nose of the nozzle. Kenmore calls this the Ultra Plush Nozzle. Cen-Tec sells it as the CT-25QD. It is also sold with the Titan T9500 canister vacuum. Panasonic designed it for the needs of owners with these soft, plush deep pile carpets that bog down many power nozzles and uprights. It glides over any carpet effortlessly yet it cleans as well as any other power nozzle I have used. No need to turn the power down and sacrifice cleaning power so you can push the nozzle.
@Vacuum Facts did Dyson try these vented nozzles @cheesewonton described?
@cheesewonton you meant this?
Any questions? Also, back to topic: @Vacuum Facts which hack do we need?
