More airflow tests.
Over 100 cfm from the hose end is very powerful for a clean air vacuum cleaner.
I measured 108 cfm from my C3 with a 1.8 meter (6 feets) hose.
Clean air vacuums don't really go much higher. It's physically impossible (hose & pipe diameter).
Well...
The highest hose end flow rate i've gotten from a Canister is about 108 my latest flow reading was 107.89, the number came from my Henry HVR200-11. The highest one i've heard of was a Lux marquis with a replaced 12 amp motor which pulled about 120 cfm from the hose without a bag.
Mini-Meet #2 Marquis Measurements
Are somewhat on the "quick and dirty" side with the Luxes. The Sentria I airflow box is exact (127.4 CFM) as I measured that Kirby several times over several minutes.
When using the GM8901 anemometer, please use only this conversion to obtain CFM from Ft./Min.: 0.0260990
It was derived from these measurements and formula.
Diameter of GM8901 Anemometer Detector = 2.1875 inches
Radius = 1.09375 inches = .0911458 feet
Detector Area = 3.1415926 x .0911458 x .0911458 = 0.0260990 (rounded)
Can't wait to see your airflow (and nozzle suction) tests as well as power usage measurements.
Bill
I am excited to test the airflow box.
Biggest challenge is to make a good seal between the nozzle and the box.
Of course I can test it with the baird meter before the GM8901 arrives (without the hose adapter).
So the formula is anemometer result x 0.026099. I will use it.
Now i need to get some sealant material for my airflow box.
I was wondering if I can cut pieces out of my blue rubber backed very low pile rug and make a custom pieces for each nozzle?
That might work, but some people use
Foam rubber weatherstripping, which is usually very inexpensive. I use microfiber cloths because I have a lot of those and they are easily configurable. They look terrible, but work very well.
Bill
Yes over 100cfm at the hose end it very good for a clean air but it drops significantly at the floor nozzle. Much more than I'd expect.
Mark
From what i've noticed the powerhead leaks a lot. If you seal the brushroll opening you can feel air leaking around the swivel neck connection and (on the SEB228) Near one of the rear wheels where there is a vent for motor cooling.
Regarding the supped up Marquis
Yeah, I re-watched the video on it the hose cfm was taken using a baird guage so we were told 110 cfm without a bag at the hose end. The flow was also not taken with a bag and that makes me wonder how much it would have been reduced looking at Bill's olympia test that machine pulled 113 from the machine without a bag and went down to 104 when a hepa bag was installed. that machine lost a mere 9 cfm at the bag chamber but unfortunately this number isn't a constant the power of the machine is going to have an influence over how much will be lost and i think it's safe to say that machine with higher flow also have higher losses. I don't have a number for the no bag hose end olympia but if we compare the numbers from the bag in test and the marquis from the video
Olympia Body: 104 Hose: 95 91.35% of airflow retained
Marquis (suped-up) Body 160 Hose :110 68.75% of airflow retained.
I've also taken a look at my Filter Queen airflow tests since i used the exact same hose wand and powerhead the only variable was the machines themselves. I see it here too where more flow is lost from the more powerful machine. Oddly the wand was consistent, possibly due to it's smooth interior?
You'd increase your airflow density due to the smaller area of the nozzle, and you would probably have a very slight increase in flow at the head. I feel though that the wessel-werk head has better agitation though, but I have no good way to measure that.
Yes the Miele has better agitation but I prefer the ET1 as the brushroll is about a third of the price of the Miele and much easier to remove. The build quality of the ET1 is very robust. 😊
That's very true!
The cost of consumables on a Sebo is often, if not always, lower than Miele and the brushroll is much easier to change.
So here is the very first test of my airflow box with the Vorwerk VK 135.
I still need to do some modifications to seal it better.
Hmm
We went from about 108 to about 85 granted i'd assume this is the majority of the flow you may get a few more cfms with a better seal. For a clean air vacuum 85 is pretty great it surpasses all but two i've the machines i've measured thus far.
I was quite happy to the result, but the seal between the box and baird meter leaked. Also the cardboard seal wasn't the greatest. It should have around 90 nozzle cfm.
Lux platinum part 1.
Well the platinum arrived today and I thought i'd have to hold off until new filters were purchased but the ones that came in it must have been very new as I think this machine was purchased in 2014. So here's some pictures and i'll place the results in the next post so one doesn't need to dig through these to find them. I cannot get a proper seal on the machine's inlet due to it's shape but I threw the picture in anyhow for fun.
Lux platinum part 2
And here are the results. This machine has the higest flow i've seen out of a canister. I do think the power nozzle holds it back. It's undoubtedly a nice machine it's very quiet and has a lot of both suction and flow (at least for a canister). I'm a little iffy about it at the time but we'll see how continued use of it changes my views.
Excellent results. This has to be the most powerful cylinder)canister cleaner available.112 CFM at the end of the hose is very impressive.
What makes you iffy about it Devin? 😁
Well
It's mostly the power nozzle. While lux nozzles are reliable (generally) I don't feel they're very good deep cleaners. The wands are also a little short for me (I'm 6'4") The canister itself is nice it's quiet it's got a powerful motor but the bag capacity and 2 filters would be rather costly over time, though i suppose if you have the money for one of these new that's the least of your worries. It also seems to have a high pull weight even on bare floors, all the wheels spin freely.
I dunno I like the style and the power of the main motor, but i just feel that power nozzle just drags this whole thing down, despite it's airflow advantage I have a feeling my Miele, Simplicity, and possibly Sebo canisters outclean this on carpeting.
Yes I agree there, the running costs will be quite high. It's a shame about the floorhead. I wonder if the new floorhead on the Lux international would perform better?
Filter(s) on GP
I have had my Guardian Platinum for four years now. Though it receives light usage, I have never had to replace the filters. The cloth bags do a very good job of filtering, of course, mileage may vary as those that use in more dusty conditions may experience more frequent changes.
Devin, thanks for the Lux GP measurements
I think it's quite a great machine but about a 32 CFM loss from the hose/wand connection down to the PN is very high indeed. Normally, I would post a pic of my Hoover Tempo Widepath (under $100) that does 80 nozzle CFM, but I already did that farther up this thread.
For what Lux charges for this machine brand new, 81 nozzle CFM is simply unacceptable to me. Mike's Vorwerk will probably end up testing near 90 CFM when his GM8901 anemometer arrives.
I've always wanted a GP and now I know what I would be willing to pay for one.
Bill
Thoughts
I kind of feel that perhaps we've seen the strongest flow we'll see out of a canister. I do recall seeing a Kenmore intuition pull the baird meter back to a 10 but since that was on one of the shop's baird meters that result could be skewed due to a worn spring. Anyhow i've put together a comparison chart and we can see all the measurements that i've taken for canisters so far. There were a few figures I either did not collect or could not collect which are marked with N/M (Not measured) I'm also working on a chart for uprights but I have a few more figures to collect before that's posted.
Bill Mike's Vorwerk is an upright cleaner.
As Devin mentioned the Aerus has the highest CFM he has measured so if that is unacceptable then every canister is unacceptable in your opinion.
Personally I think 80CFM is very good for a canister cleaner and will clean carpets extremely well!
Mark, I'm not blind yet
I know Mike's Vorwerk is an upright. Geez.
The point I'm attempting to make is twofold.
1) 80 nozzle CFM isn't much to crow about since much cheaper clean air machines can achieve this figure and
2) A 1980 Electrolux Olympia One with a new vinyl hose can get 75 nozzle CFM.
So 2014-1980 is 34 years and only a 5 CFM improvement from something that touts 505 Airwatts and 116" of water lift? Yes, I'm disappointed.
Bill
23 years difference in cfm
I had to check this one.
Lux Platinum (112.5 cfm) has 8-10 cfm more than my 23 years old Lux Royal (around 104 cfm)
I used 1.8 meter hose what is the same length than in the Lux Platinum.
Some notes about my Vorwerk airflow performance. Motor is 900w (7.5 amps)
Cfm from the body of the vacuum is 108 cfm (baird 9)
Nozzle cfm is around 85-90 cfm.
something to remember is that the canister vacuums need more power (cfm) because the hose will eat quite a bit of cfm.
Yes Mike is correct canisters need more power because the long hose strips it of power.
Bill it's not just about airflow, build quality comes into it too
Lux have excellent build quality and will last many years. Ok you won't get 120 CFM in a canister but you don't need 120 CFM to clean well 😁
