More airflow tests.
Baird Meter Conversion Table
Although I've posted this many times before, here it is again. From Baird "0" to Baird "8", the spring in the meter itself is fairly linear and amazingly accurate. The last two markings, namely "9" and "10", are non-linear as the spring becomes stretched beyond its linear limits and the graph flattens out somewhat.
The spring follows Hooke's law, that is F = -kX
Bill
I cannot be completely sure but here's my thoughts on the difference. A new bag was put into the machine to ensure the highest possible flow.
We had used a baird meter before to measure it's flow. The meter i used was the shop's, i have no idea how old these meters are but seeing as the place has a long history with kirby i'd guess they are pretty well used which could perhaps cause the spring to stretch out a little bit and lose some of it's pull.
While this should not be a factor it's not the same wand we measured from the first time. A customer needed a wand replaced and her machine was under warranty. She uses two of them for house cleaning and needed a wand pretty quickly so we figured we'd take the wand from the higher machine which was probably not going to move anytime soon. We then just ordered a new wand and put it with it. I can't recall whether or not we fully extended the wand the last time, this time was wand was fully extended.
As for the waterlift differences when taking the wand measurement i noticed an audible leak coming from these little things. With the nozzle difference an attempt to create a seal on the box causes a lot of leakage just like with most nozzles a lot of it comes from the neck of it. I also can feel a small amount of air being drawn from where the 2 halves of the nozzle's housing join together.
when doing these tests I measured hose and wand cfms first with both canisters since i tape my baird adaptor to the vane to ensure there's less loss so i know the orientation of the meter was not an issue. Wattages were close at 1149 and 1158 so the speed setting was not a factor either.
I had actually performed the C3 nozzle test twice. After taking it's initial measurements I started to take pictures and I couldn't help but think that there's no way those numbers could be right and I must have done something wrong. SO i re-tested it and got the same numbers.
I did want higher numbers from this machine. I feel like it's a really nice vacuum and, I guess, I just had higher hopes for it.
I suppose some other ways to slice and dice the testing is to swap turbo head with powered head on C3 and run tests... And do similar swap with complete non-powered hose setup just to ensure the power source is identical (understanding the 2 different units have the same motor). Why? To better control and measure the variables.
Miele U1 is great!
Blackheart: I do not want to hijack this tread but I do need to respond.
Sorry if I sounded negative about the Miele U1. I am not. I completely agree with you. The quality is outstanding, the brush is powerful and it is versatile (I can fit my Miele Twister to the wand and use it as I would with a canister).
An annoying process
I've been trying to re-measure my Simplicity S40P and I'm still not matching my original set of numbers with the dirty bag. It seems like it's for some reason difficult to get the baseplate of the machine to create a good seal with the box.
My original numbers (prior to this thread where:
1 motor: 86.83 CFM
2 motors: 99.15 CFM
Then i put in a new bag and got the numbers above. I'm not exactly sure what i did wrong in that test but the numbers were signicantly lower, i feel i may have held the wrong side of the vane to the box.
1 motor: 67.8 CFM
2 motors: 83.23 CFM
So i finally ran another series of tests tonight.
1 motor: 84.77 CFM
2 motors: 95.55 CFM
Bag door open (direct air motor only): 98.63 CFM.
Something is still off here a machine with a dirty bag should not have more flow than a machine with a clean one. I'm much more satisfied with these numbers though. I feel the Synergy are the best cleaning uprights you can buy. So I'd love to see their maximum airflow. I know a new synergy can pull a wooden dowel away from a new Kirby avalir but there's not too huge of a difference the kirby can snatch it away if the synergy is being pulled backwards. Multiple adjustments were tried same result.
I am wondering for these airflow tests if a Wood box,or even metal one can be built for these tests-with adjustable gaskets for sealing the nozzle,tool to the box.The tests are interesting,though.Vac builders should take note!
blackheart C2 measurements...
Does anyone have any guess why the C2 measurements look (generally) so much better than those of the C3... I would think that the smaller bag of the C2 would potentially cause a lower CFM recording -- but it appears that something else along the line has not only compensated for that but aided the C2 performance.
Any idea what is happening there? -- Those C2 number look almost identical to the numbers that wyaple measured/posted on a C3 in April.
I have some ideas.
Wyaple's cfm measurements were based off baird meter readings that I took. The baird meter used has likely been used for many Kirby demos leading me to believe that the spring in it may be stretched out a little which would lead to higher readings.
The measurements I took were measured with an anemometer I got a wind speed and thanks to Bill (wyaple) that can be converted to volume.
Now as to the Differences in flow. The motors are the same. the differences are in the hose and wand. The C3's hose has an electric cord running through it. Not only does that take up space in the hose but it could potentially create turbulence. The wand is also narrower thanks to the electric components being in the way.
It is still very interesting just how close the your (blackheart) C2 readings are to the ones you shared with Bill for the C3 earlier.
What is especially intriguing to me (and still feels a bit of an enigma) is not just how close the measurements are between those two data sets but the crazy drop previously noted from the end of the hose on the C3 to the end of the wand (not present on the C2 sample). IF the wiring is the airflow death source -- it seems like its effect should be felt through the hose as well as the wand. It seems like something really was going on with the wands on that C3.?. Note that the airflow differences between the C2 & C3 were not all that different at the end of the hose (Tseg's shorter hose take could account for that slight difference perhaps). Seems like there maybe more to the mystery. Love that there is a place to see this all and discuss.
It's all very fascinating.
airflow of electric and nonelectric hoses
I don't have an airflow meter, but I did notice something with my Sirena water filtration machine. It includes two hoses, one is an electric hose to provide power for the power nozzle, the other is a nonelectric hose for wet pick-up, you can also use this hose for dry pick up if the power nozzle is not needed. When using the nonelectric hose, a turbine brush will spin a bit faster than when using the electric hose, and this is when using the same machine, so there must be something slightly different with electric hoses.
Mike
Baird meters
I have access to 3 Baird meters, 1 I own, the other two belong to the shop. The measurements i gave to Bill (wyaple) used the shop (front) meter as we can see we are getting a higher reading from it vs the other two. This for me confirms my idea that it's spring is somewhat worn so there would be less resistance.
The machine used was the same Miele C3 I've been testing. It does have a little sand in it's bag but it shouldn't be enough to impact it's numbers much at all
Strangely, it doesn't seem like the cable running through the hose makes all that much of a difference in the measurements (hardly enough to have much notable effect -- 95 vs. 102). Any guess as to why (if it is the cause) it would make such a comparatively giant difference at the end of the wand? It actually looks like -if it (the power cable) was going to make a big difference in turbulence and flow the hose is where it would really hit hard (for a number of reasons) and be especially noticeable.
blackheart: Wonderful to see the pictures! The Baird meter picture is especially neat to see. You had to throw it in there. It makes the mystery go even deeper. The differences between the respective Baird meters definitely do not account for the scale/difference between the earlier (April - 95 CFM) wand readings vs. the newer ones (81 CFM).
I would be curious for experiment's sake (just for fun) to see what/if any difference existed with a C2 like the electro+ with the electric hose on. I wouldn't expect it to be terribly different but there do certainly appear to be fascinating things happening.
Thank you for sharing.
Is your electric wand the latest... SET 220? My SET 220 diameter looks the same as the non-electric, but perfectly smooth inside whereas the non-electric has all kinds of notching for the telescoping. The SET 220 has a different mechanical design to address which leaves perfectly smooth and round innards.
A friend of mine said that before saying something, one should think about it and ask oneself "Is it true? Is it helpful? Is it kind?" and not say anything unless one gets at least 2 "yes".
So, with that in mind, please realize that fun as it may be, a Baird meter is not a serious instrument for science. Just look at it and ask yourselves how you'd calibrate the 3 copies above to bring them to agree with each other in that measurement. Electronic instruments often have an auto-calibration routine, instruments that depend on springs often have something to help calibrate it to a known quantity, usually a knob or something.
Hard as this may be to hear, Baird meters were made to sell Kirby vacuum cleaners, and there's no reason to even believe they are not cheating in some way, the spring might be non-linear enough to make most of the cleaners of the time the meter was created to read under say, "5" and Kirby's read "10" despite the difference being small.
Has anyone among us put this meter to an apparatus that can generate known pressures and volumes at will and seen what happens?
And please, before you misunderstand me, no, I'm not saying this just to harsh y'all's vibes -- y'all tell me this is just for fun and I'll drop it, but if y'all are to take this all as serious, you need to do it in a more scientific way.
A lot of the differences we've been seeing here can be assigned to lots of small things -- aerodynamics is not as simple as it looks, like someone already said, just putting the hose in a straight line as opposed to curved makes a difference. When an airstream takes some path as opposed to another, all kinds of turbulence (or absence thereof) will give different results. You can see this in as simple situations as a box fan gives different results depending on how far they are from a wall, for example; that means that unless the adaptor boxes that Bill and Devin, among others, are using are identical, the measurements (airflow and pressure) they are reading for uprights will differ too.
Cheers,
   -- Paulo.
Tseg & earthling177
Tseg: Glad you mentioned what you did. I began to wonder the same as I have just had someone tell me the lumen of the SET220 is effectively the same diamteter as the non electric wand (right or wrong) and found a number of images that seem to support his statement. It really wouldn't make much sense with the SET220 design for it to be any narrower than the non-electric. Honestly though, I would be inclined to believe that the wand used here was an SET220.
earthling177: I have a science background and think you were very thoughtful in how you worded your statement. How rare on the internet! To me, this is largely fun and interesting. I definitely appreciate the time that these guys have put in for what I may not consider especially "academic" but definitely interesting and fun. Worth anyone arguing about? Not to me. Enticing and appreciated? Absolutely.
comparing a Miele C1 and C3
It would be interesting to compare the airflow of a Miele C1 and C3, with the C3, Miele says that it's a totally sealed system, they don't make this claim for the C1, I'm not sure if this even makes a difference or if it's just marketing hype, but thought I would mention it.
Mike
The Baird meter was not designed or intended to make scientific measurements! This tool was designed merely to make general comparisons in airflow between different vacuum cleaners.
It is true that most bagless vacuum cleaners generate high suction but very little airflow where most bagged units generate much more airflow with less suction and Direct Air machines generate the most airflow of all types of cleaners.
The Baird meter is also a useful tool to indicate when your bagged vacuum cleaner may need to have it's bag replaced or maybe a tune up is needed.
Bag Influence Would be Interesting to See
I mentioned it a little in my first post above, but I also wonder if the smaller bag of the C2 creates more resistance --to the extent-- that it affects the overall CFM. Or, do the respective sizes and (Miele's bag design) not fall within a size range (condition) that actually results in much of a real difference if any? Do the smaller C2 bags and larger C3 bags influence CFM?
I've seen random evidence that suggests there is little to no difference interestingly but would love to learn more on the subject.
So the old-fashioned simple fan first designed uprights outperformed the expensive clean air uprights and canisters. Looks like they even out performed the tandem air designs. Good reason to use my Kirbys and Hoover Convertibles. I think the results speak for themselves. I don't think a person can really argue raw numbers or facts.
If airflow is one's only priority, there you have it. As with many premium consumer goods, an alternative consideration is overall balance of benefits. Excellent airflow for deep cleaning of rugs, excellent suction for above floor or hard floor cleaning, light weight for multi-floor transport, large and effective filter bag/compartment to limit servicing, smaller size for optimized storage, quiet motor for pleasing vacuuming experience for you and others around, variable suction for multi-surface cleaning, variety of accessories for multi-function cleaning, outstanding filtration to limit allergens, rubberized shock absorbing multi-directional wheels for quiet maneuverability, compartment to hold accessories on unit for quick accessibility, long cord and/or hose to extend reach, auto cord rewind for ease of use, awesome color and design for viewing pleasure, easy clean or stay-clean design, perceived cost/value benefit, etc...
There is a whole other category that seems to get somewhat limited play in discussion, which is critical assessment of cleaning head performance, and performance on which surface. I'd rather have strong suction and limited airflow and a suction-only parquet head on wood floors than amazing airflow and a powerful beater-bar, for instance.
Statistics are what they are, but how they are spun by the statistician can lead to false conclusions.
Another Wrench!!!!
Well I recently purchased a Miele C3 Brilliance and I'm once again getting different figures. I think the most likely explanation for the difference in the C3 cat and dog and this unit is the filter. The cat and dog used a granulated charcoal filter where the Brilliance uses a Hepa filter. I figure having solid particals in the filter has to have some sort of effect on it's flow.
Henry!
An HVR200-11 quite a powerhouse,but the floor tool leaks quite a bit. When the ball gauge was put onto the airflow box i could feel air leaking around the joints and around the selector pedal on the floor head.
Bill
I posted on your explanation of your chart asking for a website. I found the website other than YouTube.
Nice job on dumbing science in layman terms. I really appreciate you're efforts. Its informative and enjoyable.
Aka utah vacuum guy
I need to make the hole smaller.
Now it is 2.2 inches and the anemometer is a bit less than 2 inches. Just right size hole to the cardboard piece and problem solved. Baird meter adapter fits to this 2.2 hole.
I quess adapter is only good for suction measurements?
I'm very surprised by your results for the Miele C3. I would have thought it would produce more airflow than that.
It certainly feels one of the most powerful cleaners I've used.
