Electrolux model F
The above Model F has a bojack hose. Again, the pattern colors are wrong. The suction relief valve was introduced with the Model E Automatic and all models thereafter had one, except the Model T.
As for the tape on the front cover, I hate to say it but the owners might have been using it without a bag which is why the cover wouldn't close.
Cloth bag
I think they’ve been using it with a cloth bag and sometimes these machine can be difficult to latch with the cloth bag in place because the cloth bag has a gasket as well as the bag compartment has it’s own gasket in the same area. I have a cloth bag for my F, it does shut and lock but just barely and I have to push it pretty hard to get it to latch. Plus when the automatic control feature activates with a cloth bag in the machine dirt ends up dumping on the floor when the door pops open making quite a mess so perhaps one or both of these issues is why they’ve been using the tape. Also sometime people don’t understand that to stop the door from popping open almost completely they need to turn the dial up to 6 and this user may have no understanding of how to adjust the dial or what it does and that it could stop the issue so perhaps they instead just decided to use tape to hold the door shut. They also may have been using it to suck up plaster dust or ash, both of which will clog that cloth bag almost immediately and causing the door to pop open even on 6 so they may have just gotten frustrated and taped it to keep it running.
It definitely is a mess that someone created.
It’s hard for me to tell what exactly isn’t right in the color pattern of the hose compared to the original...I think even Detroitdirtbag has difficulty seeing it. What are the exact detailed differences you see on the hose material itself Charles? This way we can learn the difference. Comparing the photos I don’t see any difference in color or pattern and not sure Detroitdirtbag does either as indicated in an earlier post.
Jon
Yes it’s hard to tell in some pics on eBay. I just don’t remember the beautiful hose, it was like all grayish.
Here’s a pic of the inside of moms. Not bad for 61 years, pays off getting good bags.
That’s nice
Very clean indeed. Bet the motor isn’t too dirty either then. Have you opened up the back end yet?
My Mom has always used genuine bags in her Electrolux’s and also not used the vac to pick up anything but just household dust...no plaster dust or ash that could go through the bag so her machines are all pristine in the bag compartments too.
Looks like no one picked up anything wet either. It amazes me how many Electrolux’s I see that have evidence of moisture having been sucked into the bag. I had my niece use my F to clean a rental condo that is going up for sale and she cleaned out the fridge and somehow managed to suck up water with the vac. The bag was all wet and split open. There wasn’t water in the fridge so not sure how she managed this plus that’s a lot of water to have wet the bag that much and there was a water stain even on the bag’s cardBoard front. She had broken a glass shelf in the fridge and sucked up the glass with the vac as it was all tempered so broke into tiny pieces and I had not left her with a broom and dustpan.
Jon
Nope, I have not had it open yet.
Your niece could have sucked up some ice cubes. My mom almost ruined the vac once when she used that cloth bag to save on bags. I remember the Electrolux guy yelling at her. He took it all apart and cleaned it. Luckily she went to him or it wouldn’t prob be around for me to fix up.
I’ll have to read how to open it up,again, I think someone posted that.
I remember her telling me he passed away. He prob had a,out of stuff laying around. York was his last name.
This is the original hose to the model automatic F. It has been in my collection since the late 1960s. Along with the vacuum cleaner, all the attachments, the power nozzle, and the original box. Look very closely at the colors and the patterns. It should help you in identifying an original on eBay.
Looks like 4 hoses in the pics
These are 2 gray Silverado electric hoses. A blue 1205 electric hose, and a super J era white non-electric hose. Electrolux phased out the metal handles during the 70s and 80s. The last metal handle I saw was on a gray Silverado era electric hose...instead of the plastic handle end, it had the end just like on the blue 1205 hose. I believe Electrolux made these for 1205 owners who needed replacement hoses and wanted to stick with the metal handles, they are more rare than common because the plastic electric handle will work with either the sheath with
Vent clip
So look on your cordwinder...hopefully the clip and broken tab from the old vent is still there. It was in one of the pics of the cordwinder you posted here. What you will need to do is use a straight blade screwdriver in the center of the slot where the hinge is. You will see a cut out in the center. Put the screwdriver on the upper part of the bump out of the clip and push downward, the is will contract the spring clip and allow it to come out from under the metal trim. You will need to use this spring clip to hold the new vent on so don’t damage it or lose it.
To install you’ll throw away only the old broken off vent hinge tab and put the new vent’s hinge bar in the groove of the clip, and fit the bottom edge of the clip into the bottom of the slot on the back of the cordwinder first, then using the screwdriver push down on the clip bump out to contract it so the top fits into the slot edges.
Let me know if you have questions...
Jon
https://www.vacuumland.org/TD/JPEG/BASKET/2020/20200921/detroitdirtbag-2020092108424900820_1.jpg
I copied and pasted this photo from your picture above, it shows the broken off vent tab and the clip. I did see a picture after this one that shows the cordwinder after Terry sent it to you without the clip and broken off vent hinge. I hope he didn’t take it off thinking he was doing good and not put the clip back in. If he did, perhaps you can ask him to mail you the clip Since It was originally with it and you need it. Since he is into restoring this stuff I doubt he would have thrown it away and can send it to you.
He took the old clip out, he kind of does what he wants. I asked for my old winder back and he said he threw it out. Also he sent a tan switch when I asked fir gray.
The vent I just bought , is is broken?
No
The vent is not broken. I was looking at the picture of the cordwinder you posted that I am guessing was going to be the one he was going to send you. But clearly after he sent you that picture he took the clip out and the broken off old bent tab. I guess you can contact him and mention that the photo shows it and ask to buy the clip from him. Hopefully it would be cheap and he will respect your wish to have the part That was originally on the cordwinder photo he sent you initially to complete your restoration rather than taking off the part and keeping it. Without the clip you won’t be able to attach the vent.
I’d contact him for sure to see if you can get it letting him know you have obtained the correct vent louver but need the clip back that appeared to be on the winder before he sent it to you.
Jon
He took it off. Everything is extra. And like I said, he does what he wants. I said send me a gray rocker, he sent a tan. I put a note in the box, he threw it out. I deal is car parts, it is t that hard.
I'd be wary.....
about that eBay seller with the hoses. Yeah, they look "beautiful" but some of them could leak like a sieve....especially the 1205 hose. And typically if I ask them about hose leakage, they either lie or act confused/insulted at the query.
I've been the recipient of both buying hoses;outright lying and plain ignorance.
Also to have those hoses shipped to me it shows $32 which I'd have to add to the cost. Plus, I have to pay tax on Internet sales now.
I've never had to fix one of those end louvers before. I looked at a couple of G's that I have. If that pic is correct of the louver, then the plastic pin goes inside of a metal barrel on the back. Now I don't know if that metal barrel pries back enough to slip the louver pin in or it comes off somehow. But the plastic louver pin in melted in place and not serviceable.
Kevin
Here’s an ides
It is basically a rectangular flat piece of spring steel that has a hump across the middle of it longways, this hump forms the place where it goes over the hinging plastic rod of the vent itself. It is just about as wide as the slot in the back of the cordwinder. You can see the hump in it from that one pic I copied above.
Jon
Wow
Yikes. That’s unfortunate. I’ll look if I have one in my parts bin in my closet but uncertain if I have one. Needle in a haystack you know. If I don’t have one perhaps a local Aerus guy would have one off an old machine. I’ve had some good fortune with some dealers that just made my day when I mentioned I had a particular machine but was missing something or a part was broken and they gave me used parts no charge when I was buying something else.
Jon
This is a very early version. There is no exhaust. The pressure inside the machine just keeps building up and building up and building up until it literally explodes. This problem was quickly remedied but not before numerous injuries and fatalities resulted from the poor design.
Hahaha!
I must laugh at you Charles! That’s a good one! I can see shards of metal going everywhere as the back of the machine finally explodes! We need some humor around here even if it includes sarcasm!
But seriously...the bracket that the cord reel uses was indeed designed with a hole in it before the reel itself...the air just blows agains the opposite side of the reel housing and is deflected all around it. Not as good of a design because it could blow floor dirt around. I’ve found though the older design cord reels like this work better though but I’ve only experienced a few of them and for their age they really worked like new and whip the cords back in quite quickly. Never taken one of these older ones apart though.
Jon
