Electrolux 1205 Automatic Control Dial replacement
al_helton
Brooklyn
Hello all!
I've been lurking for a bit, mostly whenever I had a question about my Electrolux 1205, and feel very lucky to have found such a generous and knowledgeable community.
Today I was turning the Automatic Control dial on my machine, and heard the distinct and awful crunch of breaking plastic, with the knob no longer turning. I opened up the front and found that the dial had snapped from the indicator cylinder. I tried epoxying it back together, but I'm not sure it will last.
Is this a replaceable part? Is there any place that I can order it, or do I need to get one from a matching control door assembly?
Any recommendations would be greatly appreciated!
Best,
Al
1205
You should be able to find this or a parts vac nearby.When you reinstall you will see a slight bump on the side with the ridges.This lines up with the line molded into the clear part it goes against.Good luck.
