Electrolux model F
Today was a day for wrong vac parts, I had a rocker switch coming also for the F, it showed up in tan. Not gray. Did the F’s have tan also, or is this from a diff model?
It’s perfect though, I just may have to use it, my OG one has a pc broke off on one side
That is from a bronze G
The tan would be from a bronze G or a rebuilt AE, AF, or G. Where Electrolux chose the tan color scheme for those parts. All 3 of those models use that switch and rocker cover. It will work though for you.
Jon
Hmmm
I did notice that too. All the F’s I’ve seen have had the grey switch cover so not sure if this tan occurrence is just a replacement.
Jon
The hose in the eBay listing is not a genuine Electrolux hose. It's a replacement hose with an incorrect handle end.
That one...
Is from the super J years. The super J hoses were white with the triple stripes just like this. Electrolux made non electric replacement hoses all along but in the current models coloring.
Jon
Yes don’t be hasty
Don’t be hasty and quick to buy if it’s not correct or in poor shape, one that you really want will come along...may take months or a year or so if checking eBay every day to finally find it. Don’t get discouraged either. I’ve had luck at finding just what I want in great shape for hoses with lots of persistence and patience and time. These items are rare but do come up considering how many were sold and still out there and get out on eBay instead of thrown out or sent off to a thrift store.
Jon
Not often to find these
It’s rare to find these so that’s why I sent you the link. Most people don’t take them off. If it’s gone and you can’t find another you might have to check with Bryan Satterwhite at rvavacuums.com who does restorations to see if he has one. I didn’t think the pry mark was too bad.
Jon
It’s relisted
I looked at the old link it shows no longer available but then there are options and it shows it has been relisted and I hit view relisted item. If a seller sets an expiration in the suction they will have to relist it after it expires. Unless he relisted it for you if you’ve been in touch. Yeah it’s not perfect but not bad... maybe make him a lower offer since it’s a bit damaged.
Jon
https://www.ebay.com/itm/Vintage-El...4?pageci=7f66ec62-ae56-45db-a65f-d6c4f7183e35
And my vac has the dents, lol. It’ll fit rite in.
When I use the vac, you can smell a motor smell, hard to explain, should I do anything to the motor, the repair guy prob did things over the years, but after opening up that Eureka Upright and seeing how filthy it was inside, not sure if I should open it up or leave it alone ?
Do you have an air compressor?
If you do then opening it up and blowing out the dirt would perhaps help. It’s possible the motor brushes could be causing a lot of sparking giving you the motor smell. It could also just be the rubber baffle or the metal inside that’s emitting an odor. I noticed almost all model G’s have a funny odor so could be something like that.
Jon
You’ll have to...
Take off the top cover where the switch is, unplug the cord. You’ll see a small acre holding the back end on, remove this screw, there is also one on the bottom. Then the back of the machine will slide off. There is a rubber gasket and you’ll have to put that back on when reassembling. Clean everything good around and with the gasket. You’ll notice the gasket likely has acre holes through it that you’ll need to line up when reassembling. And that’s it...pretty easy! I do t think you have to take the switch off but if you do it’s not too diffiicult just take pictures of the proper place the wires are screwed on it before taking it apart. Also the switch has a rod hooked into it that goes forward to the bag door that shuts the switch off when the bag door is opened or pops open from the automatic control. You’ll need to take note of how that rod is threaded into the switch.
I just can’t remember if the switch covers that little screw or not. If it doesn’t you may not need to touch the switch at all.
Jon
That’s nice. Only reason I’m not jumping on that is I bought all the rest of the parts I needed too fast I think. I guess I’m looking for a that brand new hose in the box still. Lol. That is tempting. A few glasses of wine I’d prob buy it.
Wow
Even I was fooled and I usually can tell a fake from a genuine Electrolux product very quickly. The colors look almost perfect compared to yours Charles. I don’t see any difference. I do notice the air vent missing so the handle must have been reused from an earlier model before they added the suction control air vent. The machine end even looks like it is an original but may have been a genuine but “reused” one. I know the modern day generic machine ends have a more curved transition between the tier steps.
I never doubt Charles Lester! His Electrolux knowledge and expertise is more than anyone I’ve ever encountered except perhaps from someone who worked for the company and paid attention to much detail.
Jon
Just noticed something
Take a look at this F for sale on eBay...it too has what could be the original hose but the handle does not have the suction control vent either. Is it actually possible that some of the hoses had the suction control vent and others did not? This would possibly make that other hose on eBay perhaps an original?
Electrolux made so many changes here and there mid run of machines even including incorrect color hoses and attachments that I’m thinking any of this is possible....
Any weigh in on this Charles?
https://www.ebay.com/itm/Vintage-El...600980?hash=item3431ab2c54:g:aSwAAOSwuwdfb6M0
