zero g canister vacuums
So it's a constellation, TriStar, airway mix? Things like $600 on Amazon.
I see 5ply HEPA bag available now, no sign of HEPA filtration or spare parts.
The power nozzle/brushroll seems interesting. Looks like you can pull it apart without a tool. No height adjust and "floating" in the carpet. What is the height clearance of this nozzle?
I like the central vac style handle, connection and electric hose. Is the hose at least 7feet?
No place to wind or retract the cord.
https://www.vacuumland.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?36210
I'll have a video on it next week. I personally met with one of the principal owners of a company Ed at the VDTA . He loaned me one for long term testing.
So far I've been impressed and oddly enough my wife even noticed how cool this thing was. I believe it might even give the Miele C2 a run for its money at this price point.
This video goes live next Wednesday 2/27/2019
If you can't wait there's a version up on the patreon on the page.
Never liked floating vacs without wheels. On bare floors they blast the surface dust around before you get a chance to suck it up. And the only way to get it to stop moving and stop hitting your feet is to forcefully pull up the canister onto a stretch of cord. Also, when the motor is off, you scratch the bare floor if you have to pull it to a new room or positioning. Not a big fan....pardon the pun.
Alex
"I believe it might even give the Miele C2 a run for its money at this price point."
Are you serious?! I think the Miele C2 Electro + for $599 would kill the ZeroG company's sales. Let's see the pros & cons here....
+ Hovers on air, no wheels.
+ HEPA Cloth bags with a tab to seal before removal.
+ High quality powerhead with good edge cleaning capabilities, which can be a pet peeve for some consumers.
+ High quality universal 32mm attachments, with the option to buy other universal attachments later without using an adapter.
+ Mini powerhead, not turbobrush, for cleaning stairs, upholstery & removing pet hair.
- MADE IN CHINA with Chinese motor & parts, vs MADE IN GERMANY with German motor & parts. This will be a HUGE factor for some consumers, especially at the price ZeroG wants for this vacuum.
- No HEPA Filter in a Sealed System. HUGE FLAW!!! What were they thinking not putting a HEPA Filter in a high end vacuum?!?! Any allergy sufferer or anyone worried about indoor air quality will immediately dismiss this vacuum for that reason alone.
- No variable speed control, & no bleeder valve on the hose to reduce airflow for certain cleaning tasks. NOT a good idea to ask hundreds for a high end canister vacuum & not have that feature!
- No cord rewinder, & no way to wrap the cord around the canister or on cord hooks. Instead, they just show how to bundle the cord up & use a cord strap to tie it up & tuck under the handle. Again, REALLY SMART IDEA going ahead & making a high end canister, ask hundreds of dollars for it & no nice way to store the cord!!!
- No onboard tool storage, except possibly to use a tool caddy. Really?!?! Even the Miele C1 & C2 canisters have a tool caddy mounted on the hose so it doesn't get in the way when vacuuming & using the wand. Really dumb idea to not think of that on a high end canister vacuum!
- Inferior quality, expensive bags. The ZeroG bags are 5 layer HEPA Cloth, vs the Miele AirClean bags being 9 layer HEPA Cloth that don't allow the vacuum to lose suction till 3/4 full. Plus the bag cost is nearly the same for both machines.
- No direct connect hose at the machine end to canister. Yes, with Miele C2 you have to plug in a powerhead cord like the ZeroG makes you do, but it's unacceptable on BOTH machines considering there's other Chinese canister vacuums, like the Cirrus & Vapamore Vento canisters, that cost 1/2 of these machines & has this feature & even MORE as standard.
I think if ZeroG wants to have ANY chance succeeding in the marketplace, they had better get ZeroG 2.0 on the drawing board ASAP! Right now, as it stands, this is another vacuum with a innovative idea but poorly executed. They should have done their market research & product planning a bit better than this considering their closest competitor is a German brand who has driven many competitors out of the marketplace & sent them packing back home.
biggest flaw
The biggest thing it would be lacking for me is the cord winder, the other things that Rob mentioned would not bother me though they may be important to others.
I actually think the Miele C1 and C2 models are made in China now but not sure on that, I know some of them are.
Mike
Mike
There are only 2 Miele C1 & C2 models made in China. The C1 Compact canisters were previously the Miele S4 series, & the Miele C2 Hard Floor was previously the Miele S5 series. These are now considered entry level models in Miele's lineup, but still retain the same quality since they use German components & only the body is formed & the machine is assembled in China, & even then that's because the German factory has only so much capacity & they are making the current C1, C2 & C3 models.
As for your observations about the flaws I pointed out in the ZeroG, I agree with you, to some collectors like yourself those flaws may not be so important. However, it's the opinion of the normal, everyday consumer that matters, & unfortunately those flaws will definitely not find favor with most people wanting to buy a new vacuum.
This does appear to be a competent vacuum.The only thing I don't like for the most part is the NOISE of the canister motor and the powernozzle.Bet the Volt would be interesting to try on this.Do like the upgraded bags over the paper bags on the TriStars and their clones.One wad of ahir blew away from the powernozzle during the hard floor test.Otherwise it did fine.I would still be nervus about using the powernozzle on a fine wood floor as shown.Who is going to carry these machines-would like to see and try one.Is this going to be a dealer machine?Its another choice in the jungle out there.
It seems
It appears to be a pretty nice unit other than the sound of the main motor and the lack of a designated place for the cord. Thank you for sharing that Alex.
OOF...
I really was intrigued by this machine and was seriously considering picking one up. However that screamer of a motor and the TINY bags are a deal breaker for me, especially at this price.
That PN I've always found interesting, at one point it was sold for central vacs, we had a woman bring one into our shop from her home in Canada. I believe it was originally branded something like the Canavac Edge. It reminds me of the setup LG used for edge cleaning that was very effective in their Kompressor machines. Besides the Constellation like floating that was one of the main draws for me.
power nozzle
I thought they made their own power nozzle, is it purchased from another company? If so, I wonder which one it is. It doesn't sound like a Wessel-Werk so it's probably something else. Yes, there is just something about the suction motor sound on this that I don't like. I am looking at getting the Cirrus canister though, it sounds really good.
Mike
@blackheart My understanding is that the patents are owned by Zero-G for nozzle.
They did make that central vacuum nozzle or let someone else make it. Something of that sort .
@n0oxy The sound is my A6000 stock microphones. They suck it's a know issue with the Sony A6000 it really dose sound different in real life. I will try to use action camera for the next video it has better microphones.
Also I wouldn't buy this . Its TTI crap from the wost parts of China Town.
Just like the oreck quest.
https://www.essco.net/Products/BI-5727
Hmm
the edgelift nozzle has been around for probably around 14 years maybe even more than that. I first saw it on an infomercial years back paired with the Airider Mach 2. Unfortunately i've never been able to find much information on that vacuum. There's a wix site for it but it's not very functional...
The official answer directly from Zero-G vacuum
"Hi Alex,
We manufactured and sold earlier versions of the powerhead on a private-label basis for use in central vacs. The ZeroG powehead is several generations removed and improved.
Regards"
Oh
Hm that's interesting. I figured the companies behind it were newcomers to the industry, though I feel like i've heard the name Amvac before.
I'm going to test one!
I contacted zero g and they agreed to send me one to test. It should be here by monday and I will have a review video posted in a week. I'll let everyone know what I think of it when it shows up.
Zero G Power
So I brought the zero-g to a friend's apartment ...my friend who watched my dog 🐕while I was out of town. The results of what was in there carpet was horrifying.
WOW AND WOW-makes me think of TriStar demos in folks homes that have bagless vacuums with stuffed bins and clogged filters!!You could have been the DTD salesman to sell them a Zero-G!!!!That tiny kitchen crumb and doormat vacuum they use just WON'T compare to a REAL vacuum!!!!
