KirbysNphones
- Joined
- Nov 5, 2012
- Messages
- 107
I brought this old beast hiome the other day, and it was in a bad way. You would plug it in, turn it on, and it would make a horrid grinding/squealing noise and shoot sparks out the back of the motor!
Well, After I got it home, looked it over, and started work on it, I was determined to bring it back to life. First I took the motor apart and found most of the problem, it had been greased WAY too much, and the old grease was on the carbon motor brushes, the commutator and the rotor windings. After cleaning out the motor, lubing it sparingly with 30 Wt non detergent, and re wiring it it runs smoothly and doesn't shoot sparks!
Now what model is it? 9 or 10, or something else?
I need to make a new front wheel for it, probably going to get a dowel rod the same size as the other wheel and use that. Also have some more polishing to do as well. Too bad it doesn't have the hose or tools, but it does have a worn out brush that went on the floor nozzle.
http://farm8.staticflickr.com/7391/10966706046_c45599a7a8.jpg
