I think your overall list of factors could use a bit of expansion, but environmental impact is a bit silly to talk about in the context of using battery powered appliances in a residential setting. Batteries are used for portability, not for performance or environmental friendliness lol. Battery powered appliances almost universally will have more of a negative impact than their equal performance/class mains-powered counterparts.
It would be funny to see a cleaning time comparison of a 12" cleaning path powerhead vs 9" or so you get with portables, especially once you factor in overlap and how how fast the head can be moved.
Your description of using a corded/bagged vacuum is funny though. Reminds me of this:
You missed the point I made. It's not about battery use; it's about the low power consumption to achieve excellent cleaning results. The battery is neither here nor there. If recycled, it's unlikely the battery will have as great an impact as the materials in a larger machine, not least the big heavy motors which are polluting to make. This scales up substantially over a population and isn't trivial. Ignoring this is a copout.
Yes, but the performance achieved must be the same and the cost to achieve it factored in so sloppy copouts can't just jam a jet engine on the back. I'm aware of no reputable test.
Well, people might attempt to trivialise it, but the data, which can't be argued with, shows clearly that people are moving away from the hassle of corded machines. Soon parity will be achieved and thereafter cordless stick vacs (DC35 clones) will dominate the market. So, those trivialisations fall flat in contrast to the data.
The additional impact from the battery comes from raw materials and manufacturing, charging losses, lifespan, and disposal.
Higher efficiency is of course a good thing, but you can't just look at something as simplistic as average wattage by itself and expect to get any meaningful insight.
I hope this isn't just devolving into another attempt at the mental gymnastics required to pretend that Dyson's current chosen form factor is the best solution for applications where it clearly isn't. That routine is getting very tired.
And the data shows it all. It and the physics have proved that the Dyson form factor is the way to go, whether it's be DC35-hand (right angle version) or the gun of V10-and-beyond (in line version), or even outright power-broom like PencilVac. You can fit a small yet efficient AND powerful motor and superior whole-machine (and currently cyclonic) sealed filtration all into a lightweight and long-lasting machine, especially provided genuinely sufficient R&D.There's no evidence that when recycled, they have any more impact than large machines with big heavy motors and all the materials needed, including transport and disposal.
I don't. I look at the data showing performance per Watt under real-world conditions.
It's not; It's a review of the data and evidence to support factual claims. Likewise, I hope your response isn't just devolving into another attempt to try to discredit and ignore when the data shows something that isn't what someone wants.
@Vacuum Facts but Dyson has already patented nearly it all, with only the oldest and most common of said patents involved having expired. There's no way around currently, though at the very least Dyson is a case of progressive capitalism... recently the mistake in the V16 and the generic-ness of the Spot+Scrub (Picea) appear to suggest the company's change for the worse...
