I like that his method allows testing the interface between the cleaning head and surface being cleaned, instead of just the airflow and suction of the motor minus plumbing losses. I saw on another video that he taped the head to the box to get peak values, but I hope that he does unsealed tests too.
A few thoughts for improvement:
- Instead of having two different opening sizes, have one side carpeted and make a removable insert for when a different opening size is needed.
- Make sensor two holes on each side. One for the vacuum gauge, and one for the anemometer. Have a few different sized inserts for the anemometer hole to simulate different levels of restriction
- It would be interesting to see the effect that turbulence and uneven airflow have on the airflow numbers. I wouldn't expect there is much impact with his setup, but having a hole in the center brace and using the side opposite of the head for the airflow measurements could help if there is any issue.
Still, even without those changes, this is a perfectly valid comparative method for a few aspects of performance.
