Wanting to Test Vacuums
The weaknesses I can see are as follows:
  • No procedure and measurements outlined to ensure consistent initialisation
  • No discussion of the distribution and placement of dust within pile — “spread evenly” is extremely vague and far more needs to be considered
  • No discussion of the properties of the dust materials and learned explanation of why they’re representative of an environment the machines were designed for
  • No discussion of the important properties of the carpet
  • No quantification of the cleaning speed and understanding why this is important, including overlap properties
  • No discussion of how to ensure accuracy of what’s measured and priming system to account for mass losses within the machine (dust sticking etc. and not being weighed)
  • No recognition, appreciation, or understand the statistical nature of particle removal from first order systems and how this is to be captured and correctly interpreted
  • No evidence of data reproducibility in any testing methodology, given all the above
Most people don’t have PhDs in experimentalism, so this is not surprising. Much of this is covered in my videos.
Even if you did all the above, without a laboratory and the necessary training, the results still have to be taken with a pinch of salt owing to lack of rigor that not using a laboratory brings.
@cheesewonton
The trend of the vacuum's removal quantity of (remaining) dirt per pass is not stochastic.
Agreed. That's not what it means though. See all evidence and explanations above as this is all fully addressed.
Now, I suppose technically if you want to analyse whether or not each individual particle of dirt is removed or not, I suppose you could stretch that into calling 'that' stochastic.
Individual particles are removed and some aren't. This is exactly what is meant by stochastic above. It is precisely mathematically modelled and empirically confirmed. There's literally no debate here and this is only revealing tremendous ignorance of well understood and solid science. Anyone who doubts this simply needs to go away, learn it all, and understand it. It has all been provided. If anyone here, of all places, thinks they know better, they'll carry no respect until they publish their findings like the actual scientists did and explain why they're contradicting them.
I challenge you to reconsider. If a particle is not picked on the first pass, is it:
1. More probable to be picked up on subsequent passes
2. Less probable to be picked up on subsequent passes
3. Same probability to be picked up on subsequent passes
As we’ve already agreed upon the answer is “2,” less probable. This means by definition the behavior is not stochastic; ie randomly determined.
You can determine this mathematically from the verified models provided above if you truly care. I recommend understanding it all if that's your goal. You clearly currently don't understand what stochastic means and the models provided for you.
Here you stated the problems.
To distribute dust you can use a flour sifter ( the type with a pull trigger that is used in dusting a cake in icing sugar.) and count how many times you pull the trigger. This allows you to pull the trigger and release to evenly cover the rug. 50 grams of dirt is about right for a 4x4 foot rug. In a home you usually encounter dust, grit, fluff and larger debris. Dust and grit is replicated by a mix of equal parts flour, baking soda and fine sand. Fluff is replicated by kpok, which is spread by holding a large clump and holding it about a centimetre above the carpet and letting it stick how it wishes. larger debris can be replicated by holding about 100 grams of clean cat litter in your hand and holding MOST but NOT all and throwing it randomly over the rug. I haven't measured how fast I move the vacuum across the rug. You could take the size of the rug and time how long it takes to do 100 passes figure that out and then calculate the average speed based on that. I vacuum in a w being straight forward diagonal back and repeat. Overlapping 50% is my standard. If I understand your second to last point correctly, science and theory has no effect on a practical test other than the hypotheses. This is why we test, to avoid unknowns and practically prove them correct or incorrect. To account for particle sticking etc you simply weigh the whole machine before and after. weighing the carpet proves what goes in and out. Hence the record keeping. The important properties of the carpet are as follows: two pile, This is tricky for vacuums as there is a loose tall pile of handle then also a very denso short pile bellow. This makes cleaning extremely difficult. Wool loop pile, wool loop pile carpet is great for creating traps and block as it is very densely made. Dust in the centre of a loop is difficult to clean!. ZSolution dyed nylon is great to represent a typical average carpet. Mohawk carpet is great for representing thedeeper piles that trap dirt. an area the size of a bottle cap can hold up to roughly 2-3 teaspoons of dust without looking terrible. Hence it is terrible to fully clean and know it is clean.
Here I responded with corrections to my method, then you quote your earlier reply that needs updating.
