Great job Mike,
May I ask for the nozzle measurements for the Nilfisk and Shark? I want to finish the interpretation of the results so all can understand your flour tests.
Kirby G6 Nozzle Area: 14.25" x 2.375" = 33.8 square inches
Nilfisk Nozzle Area: Need Measurements From Mike
Shark Nozzle Area: Need Measurements From Mike
As a preview (and guessing based on his video visuals, I'll take a wild guess that both the Nilfisk and the Shark have much smaller openings than the Kirby, say 22 square inches for the Nilfisk and 18 square inches for the Shark (both of these are guesses at the moment).
The CFM density for the G6 is 120 CFM / 33.8 sq. in. = 3.55 CFM per sq. in.
The CFM density for the Nilfisk might be 88 CFM / 22 sq. in. = 4.00 CFM per sq. in.
The CFM density for the Shark might be 55 CFM / 18 sq. in. = 3.06 CFM per sq. in.
Since Mike's carpet has much larger holes, the Shark with it's low CFM was able to get some flour. So Mike's weave might just begin to respond to a 55 CFM machine. My medium pile carpet backing is much more closed off and only starts to respond to about 75 CFM, anything lower just doesn't pickup unless you have an extreme brush roll with ridiculous agitation (Simplicity).
In two slow passes, the Nilfisk is able to come fairly close to the Kirby partly because the CFM is fairly high but also because the CFM density is high. That's the upside. The downside is that with the nozzle being significantly smaller, it will take significantly longer to vacuum large areas. For example, if the Kirby takes 40 minutes, the Nilfisk make take 60 minutes to finish the same square footage.
Some people will say that the Nilfisk is insignificantly different than the Kirby. I'll ask them this question then: If a vacuum constantly leaves 2% behind when you use it, how much will accumulate over time? Since everyone is in a hurry these days and vacuums as fast as possible and no more than 1-2 passes in one area, what will eventually be the result?
Much thanks again Mike for this video. And your bare floors look much better than my concrete ones.
Bill
