Rainbow D2 Sound Insulation?
eurekastar
Amarillo, Texas
I've been wanting to complete my Rainbow D/D2 collection with the dark brown/coppertone model.  I found one on Ebay and the description said the motor was frozen.  I received it today and disassembled it.  I was surprised to find this Styrofoam insulation inside the dome!  I've never seen it on any parts list or schematic either.
Here it is installed inside the dome.  On my other D2s the chrome can get fairly hot.  So I'm guessing this insulates against heat and sound.
With the inner baffle installed.  I can't wait to get everything put back together to see just how quiet this model will run!
The motor is shot.  I don't think I'll ever be able to get it apart.  Luckily, I have a perfectly good motor on another one that I bought for parts that I can service and install.  The paint and chrome on this unit are as close to perfect as they can be.
The Motor
This is a view of the bearing plate.  The fan assembly sits on top of it.  The one screw you see was quite stubborn.  After treating it with penetrating oil and an impact driver, it still wouldn't budge.  I guess I finally used too much force with the impact driver, because I eventually snapped that screw head right off!  The rest of the screw can be extracted, but it's more of a procedure than I want to fool with!  Besides, it's kind of useless anyway because I can't get the lower nut off the armature!
The fan assembly.  All kinds of stuff fell out her too.  I think the previous owners used it to vacuum up dry wall dust and never changed the water.  Tons of dust then got sucked into the fans and the motor probably started making a terrible racket.  Thinking the motor was ruined, they then left the vacuum sitting on a filled water basin to rust.  This is all pure speculation on my part because the exterior of the vacuum looks brand new!
<span style="font-family: verdana,geneva;">That is why Rexair/Rainbow owners manuals say the following:</span>
<ul>
<li><span style="font-family: verdana,geneva;">DO NOT CLEAN TOO LONG WITH ONE FILLING OF WATER</span></li>
<li><span style="font-family: verdana,geneva;">CHECK WATER DURING CLEANING & IF WATER GETS TOO THICK/DIRTY, EMPTY/REFILL WITH FRESH WATER</span></li>
<li><span style="font-family: verdana,geneva;">DO NOT USE THE RAINBOW TO VACUUM FIREPLACE ASH, DRYWALL DUST OR OTHER NON-WETTABLE MATERIAL(S)</span></li>
</ul>
<span style="font-family: verdana,geneva;">I always change the water after vacing every room & clean the seperator; but the seperator hardly ever gets dirty because I change the water often</span>
