Pick your poison: Main equivalency!
What would you pick?
  • Dreame Z30: Cheap shot for nice motor, cheap competitor to others
    Votes: 0 0.0%
  • SEBO Balance A1: Poor man's Dyson Cyclone V10, made by a now-wrongly praised bagged maker
    Votes: 0 0.0%
  • Lupe Pure: Anti-stick, cordless that just couldn't sustain it's existence or remaining innovation
    Votes: 0 0.0%
  • Dyson V8 (any version): Reliable&light but too cheap+compromised to be able to fully main-equivalent
    Votes: 0 0.0%
  • eufy E20: Robot stick that can barely do any job at all except for its space-saving
    Votes: 0 0.0%
  • Cheap-@$$ knockoffs of advanced stuffs that doesn't do halfway as well as any of the real deal
    Votes: 0 0.0%
  • Total voters
    16
What's the effort? Compared to what? Your criticism makes no sense. It probably cost Kenmore ten cents to make that part and there are no fasteners or anything to install to put it in the bag chamber so assembly is not more expensive as a result. The Panasonic part adds no more complexity than the release levers found on the dust bins of countless bagless vacuums. Actually it is better because there is almost nothing to break on the expander cage. The plastic is thick, supple and not the least bit brittle or prone to breaking.
I meant the R&D needed to make the bags competitive, not just improve the basic design. Also, you didn't answer me about Suction Work Rate vs. Airwatts.
Air Watts are an instantaneous measurement of both suction and airflow simultaneously at a given orifice size. It's a snapshot in time. Suction and airflow will be different for every orifice size with suction increasing and airflow decreasing as the size of the orifice is reduced.
Suction work rate measures the volume of air that flows through the opening of a hose over a period of time, multiplied by the sealed suction also measured at the end of the hose and that product is multiplied by a constant. Measuring the total volume of air over a period of time reduces the errors inherent in trying to capture an instantaneous airflow measurement so you don't have to try to normalize for the different speeds of air in a tube or pipe with turbulent airflow as you encounter measuring air watts.
The research to make bags competitive is spread out over the millions of applications, not just vacuum bags but other equipment that requires HEPA filtration. The US HEPA standard in fact comes from the nuclear industry and was developed as part of the Manhattan Project during WWII. The requirement for HEPA filters to capture 99.97% of particles 3 microns in size was driven by the need to capture certain nuclear particles that are 3 microns. The vacuum industry simply adopted an existing filter media technology to vacuums. The same tech is used in hundreds of other industrial applications. Now you are going to try to convince me it costs more to develop a vacuum bag than it costs to develop a cyclone and I will laugh out loud if you do.
Okay, and... I doubt these alone will direct measure cleaning performance on floors.
I only agree with you about the HEPA. Also it's 0.3 micron, not 3 microns.
I meant R&D effort, not cost.
So there is zero R&D effort designing bagless vacuums? Maybe you don't want to answer that, lolololololol.
Oh my god. What a cheesy move from you.
Anyways, the point is that there's more R&D effort to make the bags competitive with the bagless stuffs, and the former still has running cost and still wasteful (bagless only empty contents, whereas you have to throw the entire bag of the bagged and replace with a new bag).
I don't believe for a second that engineering a bagged vacuum is somehow more expensive and consumes more engineering talent than engineering a bagless vacuum. Document that claim or it's pure bovine excrement. Bagless machines require a steady drumbeat of new filters and the owner has to get their hands dirty cleaning the darn things. I'll gladly pay a buck or two a bag rather than have to dump that miserable dust bin out and wash filters and the bin. No thanks. And why can't any bagless machine be made with the kinds of quality materials and workmanship one finds with a Sebo, Lindhaus. Miracle Mate, Metrovac or Aerus vacuum? The bagless stuff is uniformly hard shiny miserable squeaky brittle plastic with plastic brush rolls that melt when they get hot. And don't say they don't melt because I have seen to many that did. Where is all this engineering talent when you can't even vacuum for an hour without melting the stupid brush roll? Kludge.
What makes me laugh is people say they prefer bagless as no running costs on buying bags and better for the environment. What do most do empty it into a plastic bin liner which correct me if I’m wrong goes into landfill.
I’ve owned and used both and still even though I do my bit and try to be environmentally conscious prefer a bagged machine. That doesn’t mean I don’t find bagless technology interesting and trying to use less waste like a bag or use less power to clean. I do think all manufacturers can do more!
Vorwerk with their new VK7 Kobold uses 80% recycled material in their bags for this machine. They are still certified independently by TUV in Germany. I believe from what I’ve read the 80% recycled material is from swimwear! I’m surprised no one has tried making bags from bamboo! From recent comments from them and social posts they are committed to bagged machines. Only time will tell!
From experience and observation my view on cyclones so called clogging or smelling is not always down to abuse as such! People grab and use the vacuum not looking in detail on the floor say hardfloors or carpet if there is spots of water. These get picked up by the machine with the dirt and it sticks to internals of the machine. It happens with bagged machines. The air paths can be cleaned in both types but if that moisture gets into the cyclones you can’t easily clean it. The bag you remove and replace. This will always happen as the general owner isn’t meticulous about checking surfaces before vacuuming. We don’t live in a perfect world as some seem to think we do!
What is also interesting if bagless is better why aren’t all commercial settings including Hospitals, care homes for example using them? I’ve my thoughts why!
The whole question of the environmental impact of bags is all a bit silly when you consider the context is people choosing to use battery powered vacuums in homes with outlets every eight feet. I'm not saying we should let the perfect get in the way of the good, but if environmental concerns were really a priority, corded is the obvious choice.
I believe so and there are concerns as these materials and minerals that are mined for them are not in endless supplies!
Scientists and engineers are developing ways to recycle electronic components and batteries to recover the valuable materials. I know the US military does this already when they take old weapons out of service for disposal. The electronics go someplace where the expensive materials are harvested for re-use.
