Pick your poison: Main equivalency!
What would you pick?
  • Dreame Z30: Cheap shot for nice motor, cheap competitor to others
    Votes: 0 0.0%
  • SEBO Balance A1: Poor man's Dyson Cyclone V10, made by a now-wrongly praised bagged maker
    Votes: 0 0.0%
  • Dyson V8 (any version): Reliable&light but too cheap+compromised to be able to fully main-equivalent
    Votes: 0 0.0%
  • eufy E20: Robot stick that can barely do any job at all except for its space-saving
    Votes: 0 0.0%
  • Cheap-@$$ knockoffs of advanced stuffs that doesn't do halfway as well as any of the real deal
    Votes: 0 0.0%
  • Total voters
    19
Howard Hughes commissioned Interstate Aircraft to make a vacuum for his TWA airliners during WWII. Interstate Aircraft was owned by a personal Friend of Howard Hughes, a man who co-designed Hughes pre-WWII racing airplanes. Howard Hughes specified the vacuum had to be small enough to fit under an airline seat and wanted it as light weight as possible, hence the use of the Magnalite magnesium-aluminum alloy in the vacuum body.
Compact Model 1s were already in production during WWII. I have an example of one that was made in El Segundo. They were made alongside the Kadet trainer, TDR unmanned bomber and other aircraft components Interstate Aircraft was building as part of the war effort. That plant in El Segundo was closed right at the end of WWII when aircraft production ceased. Interstate Aircraft sold their aircraft production tooling, changed their name to Interstate Engineering Company and moved from El Segundo to Anaheim. I have seen Compact C2s with data tags indicating they were made in El Segundo so that tells me that Interstate had already gone from the vertically split body used on the Model one to the horizontally split body used on the C-2 and all subsequent Compacts and Tristars since before the end of WWII.
If you still insist on claiming that your research is correct then kindly post that here. This is what my research has come-up with each time I google it. This is what I came up with from both "Google & Chatgpt" They both say the same thing. I've already posted that Howard Hughes commissions' Interstate to design a vacuum cleaner that design was the very first Compat design. Compact Model 1S vacuum cleaners were not in production during World War II, as the company that made them, Interstate Engineering Company (IEC), was focused on manufacturing for the war effort.
