Old Kirby
myoldvac
This is a picture of my old Kirby, just wondered if anyone knows which one it is or about what year it was made. It has a 2 stamped in the casting underneath near the back wheels and 495 stamped a few inches away from the 2. It belonged to our grandparents who bought it new. I believe everything is original on it, plugged it in and motor, brush and light all work. Thanks
It's definitely been rebuilt. Along with the other items mentioned, the wheels aren't original either. They would be black rubber or grey plastic (for a late 515). Has the builder's plate been removed from the bottom? It will list the model number.
A Very Fine Driver!
While this Kirby may not be all-original, at least it's been well-maintained, and whatever has been replaced has been done with Kirby parts.
As we collect, I think it's good to remember that manufacturers change and upgrade parts, and that a lot of really nice vacs have such parts on them. To my way of thinking, that does not mean the machine has been bojacked.
My Lux 1205 has the current grey wand sheath on it, and I have a new Lux hose. Both parts are actually better than the originals they replaced - the wand sheath is much stronger, and the hose is more flexible. And they are genuine Lux/Aerus parts, not aftermarket, so the machine is still all-Lux even if it's not all-original.
Certainly, the woods are full of "reconditioned" machines that have been cheaply spray painted and given a set of fitall tools, and those machines are not usually of much interest. But a good old machine that had an owner who cared enough to get factory parts is not to be sneezed at, even if there are collectors who can spot the difference a mile away.
"and whatever has been replaced has been done with Kirby
Well, no, the bag is a bojack, the belt lifter looks the same too, the wheels could be bojack too, unless they're genuine ClassicIII wheels, so, not really kept together with Kirby parts... :&#92
Took it apart and I counted 11 blades. Looked up replacement parts and on the website I found it has Genuine Kirby Lexan Fans and I counted 11 blades.
Another way to tell is by looking at the rug plate. It went through a redesign with the 514. The brush roll remained the same but the rug plate was redesigned for easier installation.
The open fork at the bottom of the handle puts it at 513 or earlier. From the 514 on, the fork was solid all the way across, like this one (see photo).
Of course, given all the bojack replacement parts, it could actually be any model from 509 thru 515, especially since there's no serial number plate.
One supposes you're fishing for its value: Probably negligible. It's old and in good condition (assuming the motor runs well) but not collectible. It's just an old vacuum cleaner.
