HI
I originally bought this none working Kirby 511 for parts and was going use it to fix up a 513 that I'm working on. Now Im tempted to try bringing it back to life. it just seems like such a shame to gut it and toss the rest into a parts bin. I don't know the history of this machine. just that it didn't work.
well, I discovered that all off the screws where loose for the bearing plate, the field coil and the motor brush holders where loose and twisted. the motors cooling fan was actually caught and jammed on one the coil screws. The little round spring the goes behind the rear bearing is also missing.
so maybe someone attempted a repair in the past and gave up? not sure. its a mystery for sure .
I did try putting every thing back as it should be and powered it up. It runs very slow and gets very hot very fast...
to me it looks like the windings are burnt near the commutator. the field coil has some surface rust but I don't see any sign of a short on the coil but cant tell for sure.
I am attaching pictures for better detail.
does anyone happen to have or know where I can by the replacement amateur and field coil ? it doesn't matter to me if its the 3 amp or 4amp version.. I also was told on the kirby FB page that DS50 or DS80 motor could used as well. I figure even if it's not original, it is better than just letting it sit . I have not reached out to the kirby co. yet as Im sure that's the most expensive way to go. hoping maybe someone with an old vac shop will see this post and have the parts.
I'd really like to try bringing this one back to life unless the parts are crazy expensive.
thanks
AJ
thanks
AJ
