Cordwinder on an electrolux e2000 canister vac
redneckchinadian
Canada
So I finally lugged my parents old e2000 home in hopes to bring some life back to it for fun and boy oh boy what the hell did I do to this poor vacuum growing up. It was so gorgeous and modern looking in 82' and my dumb teenaged self ended up beating it around pretty badly and now the case is all scuffed and will never be quite new looking again.
Today I managed to open it up and clean up the motor assembly. The bearings were starting to sound dry and when the motor would spin down that just as it stopped you can hear the bearings screeching a tiny bit. Blew all the dust out and found a few blobs of lint jammed in it. Lubed up the bearings with some furnace motor oil and really cleaned out the windings b/c it would shut down the motor after just 5 minutes of running. Purrs nicely now and the bearing screech is all but gone. Sounds like new.
The issue I have is the tension spring coil has become detached from the cord reeler. I figured out out to wrap the clockspring around the cord reeler spool and insert it into the little cutout slow BUT the problem is that the hole at the end of the clock spring has nothing to "hook onto" on the cord reel. I'm not sure if its broken off on the cord reel or if there is a certain way to hook it onto a stud after I insert it into the notch.
Not sure if I am describing myself right but the reeler was working great until I let the cord reel pull the cord in rapidly. I felt the clock spring pop out of the notch on the reel so clearly there needs to be something to hold the tension spring.
Hi,
I've attached a Electrolux Lexan tank cord winder schematic that may help you figure it out. The spring (#2) is called the drum, and #10 is the drum assembly.
Be safe; others have mentioned the danger involved if the spring's tension is accidentally released. I have had no experience in working on them other than just increasing the tension with cord wraps as one does with window shade roller springs.
Let us know if you're able to figure it out.
    8.9 KB
Thanks Paul, I will try to see if I can understand the diagram and get it setup properly. I think I was close getting it right and just needed to have a visual example of what it SHOULD look like.
You're welcome. I look forward to hearing that you got in back in operation. Btw, an old salespersons' tip to aid the cord reel function is to dust the cord with talcum powder; I have done so by putting it in the palm of my hand grasping the cord loosely as it retracts. Wiping it down first with something such as a disinfectant wipe would be a good idea, too.
Attached is a video that may also help you:
