cheesewonton
I have always kept an eye out for the floor polishers. I have only seen a floor polisher that matches a ze/za65 i was unable to look at the model number and unable to buy it as it was not for sale. I was able to see the original carrier with all the brushes in it. wish it was for sale. I do collect floor polishers if they are not too boring, I just don't know that much about them. I found in an old electrolux manual or brochure , no clue where that is now, showed the z73 or z74, the floor polisher and some flymo stuff. The brochure might have also mentioned a Z747 or something similar. I was roughly 4 when I looked at that brochure so model numbers are long forgotten.
Flymo used to sell a mower that sort of hovered above the ground, like a hoover constellation, and would automatically adjust. They were electric plug in mower, usually in makita green or bright orange. I have also seen a flymo leafblower. That is all I know about flymo. I can get photos of a makita green mower in about a week.
Electrolux z25, apparently mine was bought over from the UK. some of the accessories are from my parts storage.
Electrolux z40, I have found one on gumtree australia. There is some photos linked. Link, https://www.gumtree.com.au/web/listing/vacuum-cleaners/1329167090
Electrolux z62, After some digging here is a couple of you toutube videos featuring this model. One of them has an australian z337.
Electrolux Z89, in a few months I might, and only might, be getting an electrolux z89 to get photos of.
Electrolux Z99, No photos of info was found on this model.
Electrolux Z328 is the one in that lovely photo on TonyNZ's driveway.
Electrolux Z725, I was able to find one video featuring this model.
Electrolux D746, I can't find any photos of one. I will post them as soon as they are found.
Electrolux D747,same as D746.
Electrolux D348, I think this is the model number of the later remake of the 333 to match the D735. If i am wrong please correct me. I believe tony NZ has one based on an earlier comment.
If you look at that D725 suspension plate video ( which I have watched umpteen times ) you see the six fins and the post on top of the brush and bearing holder. The fins keep the motor from spinning and the post holds a spring that pushes the motor against its seal. You can still buy new 240 volt motors with that configuration so those vacuums can live forever. But mine are 100 or 120 volt machines and there are no 120 volt motors with that kind of brush holder. I have to either find a 240 volt motor like that from Domel, remove the brush holder and see if it will fit one of their 120 volt motors ( expensive guesswork ), or see if I can 3D print something that can be attached to the two screw holes on the brush and bearing holder of a modern Ametek motor. I really like the D720 and want to use it a lot but the original motors have a pressed on fan and can't be serviced.
