My New Aerus Vacuums
I don't own one but think the suction is probably too much for the bags to handle, I mean how much suction do you really need...combined with an aggressive brush roll. I would wonder about it wearing out the carpet. I'd keep it on the low or medium suction levels most of the time, especially if you vacuum once or twice per week. Hopefully they are resolving the bag flop.
I will
keep mine on Automatic it adjusts from low when there is little dirt to high for a lot of dirt .
 The brushroll is not as aggressive as say my Kirby Sentria and Sentria II .
 I have frieze` carpet and it shreaded the strands in the areas that are open under furniture and places like that the carpet looks like new .
Aerus will fix the problem guranteed I have zero doubts as they always address all problems on every Aerus/Electrolux this is why they have been around for ever excellent customer service/satisfaction .
Dan
I tend to always use the highest settings except on blinds and drapes. Will have to try the automatic selection more often. Really how much suction do you need to suck up a dust bunny.. Not the full power the platinum offers. But like I said previously, since I have the new batch of bags i have not noticed any leakage or pin holes in the bottom of the bag.
Imagine
Adding extra power to a vacuum could cause this issue. I would hate to shorten the life of those expensive bags and hepa's!!!
Surely they will address this issue.
I have a glass sprayer from the 70's with brass tube and spray head I still use. Works much better than the blue plastic one tat came with my legacy.
Yes you can still by the blue plastic sprayer. I think they charge 10 bucks for them. Most dealers will give you one if you ask if you are purchasing one of their machines,.
Dan, the size of the Miele bags are also twice the size of Aerus bags. Nonetheless, the Miele bags are still more expensive. Just want to keep it in perspective cause it isn't as drastic as it seems... more like $3.20 to $4.74... :)
Curtis
I went to evacuums.com for the price of course prices vary I guess I really have to make sure I ad everyting but I thought most people can figure that out .
 They can save $1.54 per miele bag with your price where ever that is from .
Aerus bags can be even cheaper if you buy generic same as Miele Aerus bags hold more dirt than you realize size doesnt really matter .
Dan
The aerus lux bags also hold a lot of dirt. They are like a brick when full and you change the bag due to the lux cyclonic action on the bag chamber. It's really unbelievable how much dirt they hold.
Mike
That is so true plus there never seems to be any loss of suction either because of the ribs in the bag chamber which allows air / suction to flow around the bag not through the bag full of dirt .
Aerus/Electrolux always had that on all of their machines the older ones had some kind of holes in the bag compartment which did the same thing to keep suction/airflow at its peak .
Dan
dan i think this is the most celebrated post ever
i am mastering the world of aerus through your eyes ....so much fun to enjoy present and future vacuums and technology....thank you for bringing it to us
Yes Dan, who would have thought your oringal post on this thread would have created over 550 responses. A Lux lovers dream :) Here is number one that started all this.
The Ultimate in Performance and Beautiful Design
The Lux Guardian Platinum is designed to be stylish and durable, with intuitive performance, so you can create a clean, healthy home. Despite a high-powered motor, operation is exceptionally quiet and two sealed HEPA filters ensure the tiniest contaminants are captured and clean air is released. Featuring sleek design and stainless steel appearance, the Lux Guardian Platinum is a sophisticated appliance. With intelligent features such as the Automatic Operation Mode that senses what type of cleaning you are performing, and the System Indicator to alert you when maintenance is needed, you'll find everything you'd expect from a high-performance floor care system.
•High-Powered Motor - Features an amazing 505 air watts and 116" of water lift.
•Remarkably Quiet Operation - The Lux Guardian Platinum features an aerodynamic air guide design and multi-layered sound insulation.
•Sleek Design - The stainless steel design is protected by a special anti-fingerprint finish.
•Performance Indication - A System Indicator alerts the condition of operation including suction level & automatic mode, prefilter notification, full filter bag and over-heated motor.
•Intelligent Suction - Suction control can be adjusted across 8 levels according to the task you are performing. Control manually or automatically. Use maximum power for vacuuming floors and deep cleaning, medium power for vacuuming upholstery or dusting and minimum power for delicate cleaning.
•Simple Maneuverability - The 3-wheel guidance system makes the canister easy to pull as you vacuum. A rubberized coating prevents scratches on wood floors and ensures quiet operation.
•Convenient - An Automatic cord winder easily stores the 28-foot cord.
•Versatility - Top-mounted power switch is operated with a simple foot tap. Switches located on the handle adjust suction and turn off the power nozzle brush roll when using on hard surface flooring.
•Ease of Use - The unique L-shape power nozzle provides 4-sided cleaning and self-adjusts its height between types of flooring.
•LED Headlight - The Lux Guardian Platinum features a LED headlight that makes it easier to see in dark areas.
•Effortless Assembly - The patented Push & Pull Connection System makes inserting and removing the electrical hose effortless. The hose rotates 360° on both ends and the handle features an ergonomic design for comfort.
•Unique Parking Positions - The canister features two power nozzle parking positions, one on the side of the canister for interruptions while cleaning and one on the bottom of the canister for storage.
•Automatic Protection - If an object becomes tangled in the power nozzle brush, the circuit breaker will automatically shut off the brush to prevent damage. A built in thermo coupler protects the motor by shutting it down if it overheats.
•No Worries - The Lux Guardian Platinum features a worry free ownership with a 15-year limited warranty
CLICK HERE TO GO TO kirbyloverdan's LINK
This post was last edited 01/09/2013 at 17:07
I too, appreciate the knowledge Dan shares with all of us! By the way, I received my bags and filters from Aerus today. New bags are thicker and a slightly different color. I cut open a bag that came with my platinum and a new bag ( since they are only a couple $ each) and there is a difference. Will let you know when I get through with one. But so far , with the pack of bags I opened earlier no dust. Just my experience. Thanks
Man I hope that making them thicker stops the problem cuz I think cheaper high filtration bags are a selling point. What about the deforming cardboard collars? I'm afraid a customer will think it's going to burst if that happens to them and will put them off.
Cardboard collars-maybe because of the 'luxes new more powerful motor-the collars should be made from a plastic material instead-like on Meile and Sebo bags.Sort of vaguly remember Air-Way had this problem-the more powerful motors in their later machines required the plastic collar over the cardboard one.The cardboard collar broke or collapsed under the suction of the newer motor.
....just like on Miele and Sebo bags. Make it like they do, their bags are sturdier! But wait, if your not crazy about the Platinum Lux bags, there are many other brands to choose from that do not have bag problems. That's what's so great. Nothing is perfect, even a $1300 vacuum.
Preaching what I learned on here, happy vacuuming :-)
My New Aerus vacuums
Rex,
You are correct about your comment on the Air-Ways. I had almost forgot about the problem they had when they went to a more powerful motor. Same thing happened. They could no longer use the cardboard top on the Sanibags as the suction would pull them out of place in the top. My parents had this happen a few years ago with their 88. We bought a new motor thinking thier motor had gone bad after over 40 years use. It was NOT the motor but only the off/on switch. Anyway I installed the new motor and we had a problem because they still had some of the older style cardboard top Sanibags We had to discard them and use only the newer Air-Way Sanitainers with the thick plastic tops. It DID resolve the problem.
I never owned any Electrolux that DIDN'T have a thin layer of dust on the inner cage after time (NOT dust leaking-just a thin layer of dust reidue when you ran your finger accross the inner cage) but if you find ANY dust on the inside of an Air-Way-you have a problem with the bag or maybe a fake Air-Way bag.
You have a good memory!!!!!
I just
called Aerus today and a lady named Debbie said that Vicky whom I spoke to about my bags and HEPA filter forgot to send them to me . She promised they would ship out tomorrow , I will see once I receive them if there is any improvement .
So if anyone else is having problems ask for Vicky since she knows about the complaint .
Dan
Let us know Dan. I just checked my first bag of the new batch again today. The bag is pretty close to full and the new hepa filter is still very clean. There is a little dust in the chamber but very little. I think too dust in the bag chamber is more noticeable cause it he chamber is black. My legacy and older luxes are light color so the dust doesn't show like the black.
Dust update
I have been using my platinum with the new bags and filter about every other day. I checked today and no dust, and a clean filter. I don't know if the problem is solved, or I've just been lucky, but so far I'm satisfied.
