Fact vs Fiction...
<p class="MsoNormal">Niclonnic: most everything you believe about bagless vacuum cleaners is incorrect. There are at least three misconceptions about bagless vacuum cleaners, so I will try to correct them here.</p>
<p class="MsoNormal"> </p>
<p class="MsoListParagraphCxSpFirst" style="text-indent: -.25in; mso-list: l0 level1 lfo1;"><!--[if !supportLists]-->1.<span style="font-weight: normal; font-size: 7pt; font-family: 'Times New Roman';"> </span>1. Bagged vacuum cleaners lose suction as the bag fills up. This was true about the early paper bags in the older bagged vacuum cleaners. However today’s modern bagged vacuum cleaners use a synthetic type of cloth bag which does not have pores that can clog up with dust. These bags also provide HEPA filtration so the vacuum cleaner cleans the air as you vacuum. I have proven this with my Kirby Sentria which uses this new type of cloth bag. I have a Baird air flow meter which is used to measure the suction and airflow of any vacuum cleaner. My Kirby Sentria reads a 7 ½ out of 10 with the air flow meter connected to the hose with an empty bag. When the bag is ¾ full the reading on the air flow meter is just under 7. So you see hardly any suction or airflow is lost even when the bag is ¾ full.</p>
<p class="MsoListParagraphCxSpFirst" style="text-indent: -.25in; mso-list: l0 level1 lfo1;"> </p>
<p class="MsoListParagraphCxSpMiddle" style="text-indent: -.25in; mso-list: l0 level1 lfo1;"><!--[if !supportLists]-->2.<span style="font-weight: normal; font-size: 7pt; font-family: 'Times New Roman';"> </span><!--[endif]-->2. Bags are expensive to buy. Actually in the long run, the filters in Bagless vacuums cost much more to replace than bags. Some of these filters can cost more than $40.00. However a six pack of cloth HEPA filter bags for my Sentria costs about $18.00. This is enough bags to last me for two years of normal vacuuming. I can vacuum my home for 3 to 4 months before needing to replace the bag.</p>
<p class="MsoListParagraphCxSpMiddle" style="text-indent: -.25in; mso-list: l0 level1 lfo1;"> </p>
<p class="MsoListParagraphCxSpLast" style="text-indent: -.25in; mso-list: l0 level1 lfo1;"><!--[if !supportLists]-->3.<span style="font-weight: normal; font-size: 7pt; font-family: 'Times New Roman';"> </span>3. Dust flies out of the bag when it is being changed. The fact is almost all of the bags used in newer bagged vacuum cleaners have a flap that closes over the opening of the bag as it is being removed from the cleaner which prevents any dust or dirt to escape from the bag during disposal. You just drop it in the trash bin and that’s it. Therefore replacing the bag is a much cleaner process than emptying the dirt cup on a bagless vac.</p>
