blackheart
Well I've decided to give it another shot. This time measuring my own 75th anniversary edition and the M360 (black) which i borrowed from the shop i work at for testing purposes. The 75th uses a dual stage motor, not as long as the triple crown but it is indeed a dual. The M360 uses the new single stage. Both of them have had their container and seal cleaned and a new genuine cellulose cone installed. I also used the same hose wand and power nozzle for both machines. So how do they stack up? Let's see how they did. But first lets look at a few specs on them. Using a Kill-a-watt meter i was able to see how much wattage each machine used.
The 75th drew about 947 watts on high
the M360 drew about 1108 watts on high
A waterlift guage was attached directly to the machine bodies to compare waterlift. As can be seen here the 75th did, surprisingly, slightly better.
