Filter Queen 75th and M360 (black) airflow losses
blackheart
North Dakota
Well I've decided to give it another shot. This time measuring my own 75th anniversary edition and the M360 (black) which i borrowed from the shop i work at for testing purposes. The 75th uses a dual stage motor, not as long as the triple crown but it is indeed a dual. The M360 uses the new single stage. Both of them have had their container and seal cleaned and a new genuine cellulose cone installed. I also used the same hose wand and power nozzle for both machines. So how do they stack up? Let's see how they did. But first lets look at a few specs on them. Using a Kill-a-watt meter i was able to see how much wattage each machine used.
The 75th drew about 947 watts on high
the M360 drew about 1108 watts on high
A waterlift guage was attached directly to the machine bodies to compare waterlift. As can be seen here the 75th did, surprisingly, slightly better.
And first the 75th anniversary.
I was going to go through and do the measurements again with a medipure filter but decided it was too much hassle so i just took a nozzle reading with it.
With medipure @ nozzle 63.71
Without medipure @ nozzle 68.85
Filter Queen 75th edition
I have the 75th anniversary edition that I got from Phillip in the raffle at the official Vacuum Cleaner Collector’s club convention this year in Tulsa. I really enjoy using my Filter Queen the improvements on the power nozzle really make it an excellent carpet cleaner.
Oh, I'm lovin' these tests!
Keep going! What's next? Rainbow E2? A 10 Amp Royal? Lux Guardian Platinum? Miele something-or-other? Whoohoo! Great work!
Bill
Next
One of my favorite canisters, the Tristar CXL. Hmm of the above machines i have 2, a rainbow E2 (black) and a Miele S7 upright so those will be coming in the future.
dual stage motors
The dual stage motors are actually more efficient but surprisingly are not used much anymore, the industry has moved to single stage motors that spin much faster, sound like screaming jets and in some cases, draw more power but don't provide any other benefit other than being smaller. It's very hard to find a portable vacuum that is currently made that uses a two stage motor although it's really common with central vacuums. the only vacuums I can think of that use two stage motors that are still made are the Metropolitan canisters, and the miracle mate and patriot. The other machines that used to use two stage motors have gone to one stage motors, such as the Aerus classic, Tristar which Aerus now makes and filter queen.
Mike
I use
A GM8901 anemometer if you measure in ft/min you multiply that figure by .026099 to get cfm, Another member calculated that out i just use his Figure. I also use the cuff from a baird meter to get a decent seal to the vane, and then for nozzle testing i've built a sealed wooden box to redirect all the flow to one hole for measurement.
I am going to build the airflow box. I also make different sizes adapter plates to fit my vacuum cleaner heads. For a seal I am going to use foam.
GM8901 Anemometer is coming.
Box
@blackheart, Doesn't the hole itself reduce the airflow and invalidate the test? I assume you've made it that size to fit the manometer, but Kirbys don't actually work like that when the brush housing is used. Please correct me if I'm mistaken.
*shrugs*
I'd imagine forcing the airflow through a smaller opening than the original probably does reduce it somewhat, however I cannot imagine it's a significant amount. I was getting a reading of about 137 or 138 for the Avalir. Even if the numbers are not fully accurate they still provide a comparison using the same tools, techniques and variables.
Actually
It might not affect the results any more than attaching a Baird meter to any opening, since the meter itself has a fixed diameter. Even if it does affect it, it's consistent. Ultimately, you have to have some way to test airflow at the level of the floor nozzle, so I'd think that's as good as any. Are you able to put other uprights and power nozzles onto that box, or is it sized specifically for a Kirby?
