superjfan
Dear Forum Members:
I was given an Electrolux Super J that seems to work well, except for the bag door being loose. I can use the vacuum after the bag door is closed, but if the hose tugs at the door, the machine turns off, and the check bag indicator illuminates.
I checked the latch, and it does not appear to be broken. However, the door seems loose and has a visible gap around the sides, even with a new bag inserted. Is there a way to tighten the door or the latching mechanism easily?
Thank you for your help!
SJ
SJ
