Electrolux Automatic E
justjunque
Western MA
Greetings!
I was just gifted an Electrolux Automatic E. It's my only metal-bodied Electrolux.
I'm currently cleaning it up, and I think it will look quite nice.
All I got was the main unit. In addition to needing a hose and attachments, the vacuum does have some issues.
One rear wheel is broken at the "hub". A really good glue that's safe for plastic would probably take care of it.
Also, there's maybe a foot of what appears to be the original black cord coming off the machine, and then someone has spliced on a grey cord.
Finally, the flared chrome piece, or "halo" that the cord wraps around is missing. Actually, I don't know if this machine originally had the halo, or a retractable cord.
The bigger issue is that, while the motor runs, and sounds smooth and quiet, there's very little suction.
From a practicality standpoint, I could probably find an Automatic E that's ready to run for what it would cost to fix this one. But, I'd get more satisfaction from knowing that I saved this machine from being scrapped, and put it back into rotation.
Does anyone have any thoughts on the problems; specifically, the low suction issue? The door to the bag compartment seems to close quite snug. So, I doubt if that's the problem.
Provided the vacuum can be made right mechanically; is there a good source for a quality replacement hose for it? I know they're out there. I'm just wondering if anyone knows of one that's of better quality.
Thanks for reading!
Barry
Low suction is due to a bad rubber motor mount. Happens a LOT to machines more than 50 years old. The model G was the last model with the three-screw motor mount design. I'd find a good donor model G and take it's motor and swap with yours.
Thank you for the info.
Not what I was hoping to hear, but I appreciate knowing. Since I don't work on them myself, it's not going to get done as long as I own it.
At least I won't spend any time or money tracking down a hose and attachments for it.
Perhaps, some day, I'll pass it along to someone else who has the skills and smarts to fix it up.
Also,
You might check the fan(s) for build up on the fins. There could be a lot of crud packed in there which would definitely have an effect on air flow and suction.
... and also check for debris in the wands and hose. The Automatic F that I picked up last week had a partial wand blockage, but now has great suction. I suspect it was donated to Habitat for Humanity and discounted down to 75% off after months of sitting on a shelf because its suction was low. It seems that so many people of this decade presume that the proper way to deal with broken equipment is to toss and replace.
On the cracked wheel, my F appears to be ABS, so one might presume that the G also is ABS. A solvent cement such as Testors 3502 should work well. With careful application, a nearly invisible and permanent repair can be made as long as you have all the pieces.
