Dyson Piston
It's so minor in general and there'll always be some basic maintenance. Would be nice to be solved though.
This is exactly my point. No one cares. What a shame.
Understandable. That being said, I really hope you're going to still doing ok by the time the dust has settled metaphorically (and in the process, literally before you clean up your home). 👌
@Vacuum Facts @vac14012 @shattered @cheesewonton
If you want to talk about the fix needed to get the (initial batch of) V16 working superbly again, please go to my own thread talking about the fix in question. For now, I'm talking about the new dual-cone head, or as it's officially called, All Floor Cones (Sense). And by extension, both the olden Digital Motorbar and the laser soft roller.
This new head is designed in the same manner and with the same intended role as your typical brush bar and soft roller into one single cleaner head, much like the first iteration of the digital brush launched with the V11. The new head is patented new design, using two Archimedes-cup (excuse me, but Panasonic themselves duped the design as detailed in one of VF's own videos himself) opposed and attached to their base (not between the tips like Panasonic's version), and a slim wall compared to the hair screw tool (the originator of said Archimedes-cup design), designed for, you guessed it, full-blown hair de-tangling without sacrificing much edge cleaning. The whole thing is wide-V shaped at the front, which makes it annoying to clean with the front and reduces the cleaning effectiveness of the front wall and corners, the former forcing you to use the head's sides to do the job (in other words: forcing us to rely on edge cleaning); said front wall integrates both the typical Dyson adjustable gates (similar to the ones in all the named versions of the digital bar, not the regular Motorbar though) and a new (and brighter!) version of the laser technology from the laser soft roller. There are little front wheels at the front corners (that may be tangled, unlike the rollers themselves), and the same kind of 3D-sculpted squeegee back as the digital bar. The V-Ball are also taken from the digital bar and even the regular Motorbar as well. The laser soft roller, meanwhile, may be merely ported from regular attachment to the new digitised attachment for the V16 (which is not directly compatible with any of the previous tools at all - it uses different connector than its predecessors), so no true de-tangling at all.
(To be continued...)
I would propose as what if I redesigned the new head and the soft roller, so here I am...
- I go back to the two-head strat, providing both the actual brush bar and the soft roller. These would be the dual-cone head and a redesigned version of the soft roller, respectively.
- Dual-cone (All Floor Cones) is the brush bar:
+ Keep the Archimedes-cup design from the original, making that two screws that dives deep into the piles in carpet and sweeps hard floors as well. There needs to be an XL version, then said screws must be symmetrically expanded and modded with extended tips like the hair screw tool with the same minimal walls both inside and outside, giving us both good edge cleaning and actual hair de-tangling from the original dual-cone; these extended tips becomes relatively low-profile got both itself and the edges of the proposed head, making it slightly more flexible in low-profile cleaning, taking advantage of the resulting conical shape already present in the original head.
+ Make the rollers' physical brushes, with four spiralling stiff almost-short nylon strips and soft roller-based swaths of soft bristles based on the PencilVac's FluffyCones rollers, all replacing the two strips and two brushes, and the plastic space, respectively. This redesign is based on 360 Vis Nav's own multi-action brush bar which literally combined the ordinary brush bar and the soft roller into one. You get doubled carpet agitation and make it easier to clean even the most stubborn dust in the piles, while the increased area of soft rolling improves both hard floor seals (similar to the soft rollers in general) and sweeps more dust in less time within the same sweeping path. (After all, Dyson wants us to treat the original new head as both brush bar and soft roller in one)
+ Slim down the center of the front wall, and slightly straighten the front wall. This restores some of the front cleaning performance, and make the corners easier to clean. Keep the centered laser in, but optionally add two bright white LEDs (akin to regular LEDs on various dupes' many heads) at the sides that only turn on while on carpet (especially since the green laser turns off completely on carpet), so you can see stuffs in the dark
+ Taper the base of the rollers similarly to the PencilVac's FluffyCones, reducing the unswept path at the center. Also taper the strips and the bristles slightly outwards in the tips and slightly inwards in the base, reducing the unswept path even further. That plastic strip between the rollers can then now and would be-be replaced with any straight rigid thin-wire at the center, similar to the similar wires under the brush bar of Vis Nav.
+ Modify the squeegee, base it partially on the regular Motorbar. This hybrid squeegee should be able to sweep off and retain seal without ploughing the back or scratching the floor. That kind of rubber strip should seem like a reversible version of the current 3D-sculpted squeegee ones found in the original and the digital bar (currently too focused on sealing and sweeping front, that would snowploughs any mess on the way of the back pull).
+ Keep the automation and detection from the original. Final result: an even better all-rounder brush bar than ever, fixing the problems compared to both the old and new heads, true de-tangling even the longest of hairs and strings, and superior cleaning performance per suction-airflow-power (i.e. airwatts) on both hard floors and carpets. The original new dual-cone head is really good (and not nearly as loud as some made out to be), but this proposed design is even better.
- Soft roller (All Floor Motorbar) is the soft roller:
+ Adapt the brush bar from Vis Nav, with the strips and the bristles from V16's dual-cone head (present in both original and my proposal) in place of the thinner strips and older soft rolling respectively. The thicker and fuller strips and softer bristles improved cleaning performance across the board without really scratching the hard floors. The carbon fibre filaments are optional - it strips away static charges from the dust in hard floors but may scratch the floors in the process (and the dual-cone head did away with these filaments). Also keep it about as low-profile as the previous laser soft roller, so low-profile cleaning could be taken care of.
+ The de-tangling vanes from the newest versions of all pre-dual-cone bars. While considered a stop-gap solution, it's still pretty effective at what it does: de-tangling hair, just like the conical Archimedes-cup design in the hair screw tool and the new head, albeit much louder and less long-term durability.
+ Strip down the front wall like the Vis Nav and the soft rollers, not only to facilitate the redesigned multi-action brush bar but also to prevent as much snowplough at the front, and allowing all (not just some) large debris in all at once - the proposed/redesigned dual-cone head can keep the front wall and the gates which only allows only some of those large debris in at once at best.
+ The (brighter version of) side laser from the soft roller. Maybe even stops being perpendicularly straight laser which only light up the opposite side and front like the initial versions of the laser, and become more like the wide-blade laser from PencilVac and V16 instead. The redesigned laser, like the one(s) in the dual-cone head, will turn off while on carpet, and back on when back to hard floors.
+ Bring the automation and detection from the dual-cone head. This means the brush bar can change speed like any version of the dual-cone head does. The end result: a soft roller that have stiff bristles alongside soft ones, capable of sweeping both dust and debris of all relevant sizes regardless of floor types, from hard floors to carpets and back, and there would be no extra unswept path to boot. It would also be low-profile, so freely be able to clean low-profile nooks and crannies.
[To be continued...]
Dyson thought they could replicate both the normal brush bar and the soft roller into one, and if there's every nickel for every time so, we now got the second nickel with the V16 (the first one was the V11). While swapping cleaner heads has been relatively quite the trouble primarily because you have to bend, V16's cleaning wand already solved that with the red cuff near the top, making the head swapping so easy and simple and effortless, the two-head strat from the past since the birth of the (Fluffy) soft roller has finally become viable. The hopefully-ultimately redesigned as I proposed, version of the new dual-cone head for V16 should be the brush bar with front wall, gates and technically bulky head (maybe in two sizes) for cleaning carpets deeply but also capable of sweeping the hard floors and de-tangling hair all efficiently, and the redesigned hybrid brush bar be reincarnated and re-engineered from Vis Nav into the soft roller for V16 (not the porting of the laser soft roller as is the case of the current market in certain regions), while similar deep-clean performance on carpets but superior efficiency at hard floors through the opened or lack-of front wall and designed as low-profile for low-profile cleaning like the old laser soft roller, and both heads have the same intelligence and similar lasers as the ones in the current dual-cone head already present for the V16. Only the redesigned multi-action soft roller can be ported back into previous models (partly because that should've been included in the later releases of something like V12, or Gen5, or earlier of V8 Cyclone), while the redesigned dual-cone head can continue be incompatible with anything that came before the V16.
And we know Dyson has all the R&D to make the new heads as I proposed. After all, they innovates, while the competition dupes and copies in such ways that tend to hurt the originals which are almost all Dyson's (The only truly innovative things I could think of in vacuum cleaners that Dyson didn't do first were the auto-empty cleaning stations and the bulky dual brush bar heads...), just as @Vacuum Facts said himself many times.
So yeah, that was all I have. Sorry, my talk was so long, it exceeded 10,000 characters and forced me to split the thing.
According to this reddit comment, (could be BS of course), but they were working on an upgrade to the VisNav but Dyson cancelled it before mass firing loads of people in the UK. The entire new Robot Vacuum is Picea designed with a Dyson logo on top except for the Cyclone taken from the VisNav on the dock.
What a shame if that's true.
I'm trying to remember the last time Dyson did anything like this. Would this be a first for them?
The only instances I can remember is the DC02's original head, which was manufactured by Wessel-Werk.
I'm amazed by what I'm discovering about the V16 and what this says about internal management at Dyson. I've lost so much confidence in them, even though there are still some great minds there doing good engineering and inventing solutions in the way they always have. The choices this generation have just shocked me.
Not gonna lie, V16 is a tragic machine. Dyson's internal management screwed up BIG time!
In the future when James isn’t around, design processes could become even more convoluted. I believe good engineering requires a deep passion and dedication to the issues one is solving. Perhaps this group of engineers are losing interest in vacuum cleaner advancement, in favor of other product technologies. Of course, this is just my speculation on the subject.
If it ever gets shareholders, it's game over. Their apparent problem currently is they got too big. Big companies are messily managed. You need a suit. Suits are scum who see profit above all else. Dyson could be on the slippery slope to the same place everyone else is. The details of the V16, which absolutely no one is talking about, reveal so much about the suitism seemingly going on there since last year.
Who's ever in charge of naming the products needs to be fired yesterday, the product lines are beyond confusing if you're not an enthusiast. So many dumb name changes and just general confusion. Like go to the website and pretend you're not an expert, you'd have absolutely no clue what is what. It's even worse now that they've gone from V15-GEN5-V16.
And even someone like me who knows a lot of about Dyson vacuums: https://www.dyson.com/vacuum-cleaners/cordless/v9/motorbar
What the hell is a V9? Literally never seen this before, and google brings up nothing
TechRadar covered this already: https://www.techradar.com/home/vacuums/dysons-vacuum-naming-system-explained
Also, the V9 is literally the current version of the Digital Slim, based on the V11, but you wouldn't know much based on... well, much of anything at this point.
The naming scheme is quite ridiculous. For example, the Gen5 could've been named V15 Advanced (Detect) and V15 Outsize (larger duh), but no, Dyson had to emphasize their new motor! And then there's the "Cyclone" too!
If only Dyson could keep their naming truly straight... we could've have been using like... well, this: V1 (renamed from DC35 for consistency) -> V6 (Fluffy) -> V7/V8 (Absolute) -> V10 Cyclone (added "Cyclone" only because it's a new era but that is confusing at the end - just look at the newest version of V8 - so keep that for V10 only) -> V11 (Outsize) -> V12/V15 Detect -> V15 Advanced/V15 Outsize (Not falling for 15-5-16 crap again; also, V8 Advanced exists) -> V16 Piston (no "Animal" necessary in the name)... Same V-number advancement but much, much less confusing. And the Digital Slim that's renamed into V9 should've been named the V11 Slim instead, as does the small-bin V10 should be Cyclone V10 Slim (Small-bin V15 should never have existed, we already have V12); what's currently named V8 Cyclone should actually be V8 III (V-eight mark-3), after the fact that it's a whole new version of the V8. From original to Advanced to III and onwards, and the pure and obvious advancement of numbering in V is the way to go, and I think Dyson did a decent job until between V10 and Gen5, and they screwed up the naming. Not to mention every lightweight-manuveable cordless too, which should've all been named like "Glide" (no more "Micro" or "Humdinger"), and then to the new PencilVac (which thankfully is descriptive enough of a name because it fits its thin form factor).
Seriously, Dyson needs to rename the offenders, as I have proposed.
At this point, we should be protesting Dyson someday. I'm not even sure how much control family will have left over the company once James Dyson himself passes away. You guys are telling me shareholders will only make Dyson bigger and that would only make things worse. This is understandable because the internal management is starting to crack. Look at the V16 and how it's effectively crippled by one singular mistake stemming from a bunch of bad decisions - thankfully it's correctable. Look at that Picea-made Dyson. Look at the current state of the award-winning customer support (it's absolutely atrocious). Because I and @Vacuum Facts neither are Dyson fanboys, we have no incentive to sugarcoat anything. I'm going to straight up say that Dyson as a company is secretly on verge of losing themselves. After they've made their solid-state batteries and bring them to market (thus upgrading maybe V17 or -ish into a whole new league of mains-equivalence, for instance), I'm not sure where would they even go next except for maybe their beauty stuffs, especially now that they've completely scrapped their electric car years ago already.
Dyson's best bet appears to be becoming like Apple but focusing on small appliances and beauty stuffs, such as their mains-equivalence, their hair dryers and stuffs, their fans and purifiers, and their cleaning and beauty solutions. And they have to keep their most passionate and dedicated engineers, and keep all the engineering attitudes they still have left, otherwise they could finally lose and Dyson truly dupes themselves like they accidentally semi-did the V16 at initial batch. We love Dyson machines (both vacuum and fans), but we currently can't stand the current state of the goddamn customer support. We need to get ready and call Dyson out every bad decisions they've made so far, up to and including at least what crippled the V16 to begin with. All the bad decisions, all the messes, and all the internal hassles, should be ironed out with our help - we have to take matters in our hands soon, or Dyson will fall into the same regressive capitalism as what made the current dupes so bad compared to Dyson's machines.
Isn't the v15 Detect a normal sized bin though? Pretty sure that's what I have and it's not a smaller one like the V12. The fact that we're having this discussion shows how bad the marketing is though.
V15 is indeed normally a "big" bin product, just like all other ones since V10 except for small V10 and V12. (Digital Slim is named V9 now) And yes, small V15 exists, and it looks like a chunkier version of V12 with the trigger instead of a power button. Could Dyson have just slapped a normal small-bin and not the even smaller bin we got for V12? Also, with the new dust compression tech, the V16 became hybrid of both big-bin and small-bin though not exactly to the levels of the HUGE Outsize models.
The rest is just as I said.
From what I’ve read in the past James and his family have no intention of allowing share holders become part of the business and selling it out to share holders. The whole family is involved in the business and making board decisions. His son Jake no doubt will take over as he’s heavily involved like his father still is. They have a CEO to run the day to day which I believe gets changed quite regularly of more recent times and the latest one appears to be putting profits before true engineering which is or was there main foundation.
The family need to get together and sort this internal mess up and bring back the award winning customer service they once had and stop outsourcing things! If I was James and his family I’d be ashamed of the amount of unhappy owners and complaints you read. It’s shocking but that just tells me that they just after more money too. They have got to big and greedy.
Tell all that and issues to the family themselves. James Dyson himself needs to do something about all this. They should also deny shareholders too, just as they have been doing. Fix the management, patch the R&D
He should and must of known about all this which has been going on for a few years or more now but chooses for whatever reason to ignore it. Which is complete madness!!!!
If I had direct contact with him I would tell him.
What makes you think he is not the root source of it? Do you think he did not participate in the firing of almost every UK engineer throughout the years, or the outsourcing of almost every single role?
The amount of copium is insane, this is not some evil C-level move being done by shareholders, whether dyson goes public or not, the enshittification is already here and has been developing for years, it's just that it's finally reaching to the end product.
Dyson used to have a forum similar to this one that was once very friendly and active, you could even become a community "vip" if you were active enough, being promoted to "vip" got you free stuff and meets with internal engineers, PMs, etc.
That was the theory, in reality, the community was quickly overwhelmed with negative reviews from every posible angle, they had to shut it down this year because it was that bad.
He probably is but no one knows for sure. We are all speculating in the most part.
Yes we can see certain things have changed and the amount of negative reviews and comments from owners should alert the owners ie James to sort it out and step in. But yes if it’s coming from him then it probably be the beginning of the end for them!
It's no speculation that Dyson has been cutting on every single corner that impacts product design and engineering. A company that is product-first would never do that.
They are well aware of it and it most likely does not matter, Dyson has a brand that can take a lot of hits before it impacts revenue, they will continue this enshittification which will work for a while before it hits their overall revenue.
This is not a 1-time blunder, Dyson has been building this situation for years and it will only worsen from here, anybody thinking otherwise is delusional.
The PICEA robot is the first product they've outsourced to a third party for development though. Sure they've made some duds in the past but at least they were all in house.
The only hope is that no one buys this thing compared to the in house developed products and they reverse course but I'm not getting my expectations high.
About time we take matters in our own hands. Perhaps we can actually try destroying those Picea robots out of deliberate spite. No, really, even though I wouldn't normally recommend doing that AT ALL. For sake of the actual engineering, might as well try destroying the Picea robots ourselves.
The robot is the first piece they have completely outsourced, however, they began outsourcing internal job positions years ago. It began with support agents, they told employees from the US & UK that they were there to help them out and would not take their jobs. Within 10 months most teams had seen the first round of layoffs.
They moved the bulk of operations from the UK to Malaysia, they fired engineers on every single branch of the company, began hiring a TON of interns that were burn through while being promised permanent job offers that never came through or were ridiculously low valued. For over a decade Dyson has been cutting both jobs and quality on their products.
People is not ready for what is about to come, having somebody linked to tata as a C-level is the absolute worst news to any company, the decline of the company will only get sharper from here on.
This might sound dramatic but I have no doubt time will tell.
The only way we can fix this is to get the matter viral. Extremely viral, turn it into a full-blown controversy.
Parwaz lasted video on the Piston has solidified to me that this thing is complete garbage at vacuuming and Dyson should be ashamed for releasing it.
While yes it is a very extreme over the top torture test. Yes no ones homes are ever going to be this dirty. Buuut compare it to his similar Gen5 video.
V16:
Gen 5:
The V16 has the horrible unswept path, shoots dust out the back and generally just looks like extremely poor pick up and suction/agitation. The hard floor test also is atrociously bad.
The Gen5 on the other hand has no problems. Cleans the carpet exceptionally well at least visually, and only clogs when he really tortures it by trying to vacuum the entire bin contents.
Good luck to anyone who buys it. I expect it to be discontinued fast like the Cinetic uptights.
In fact check out his video using the Dyson Cinetic Canister. This thing doesn't even have a power head. Just a suction powered turbo tool and it seems to perform way better than the V16. That's sad and atrocious. I'm pretty sure this is the lower powered version too to comply with EU Vacuum regulations.
Exaggerated initial mess levels indicate nothing about real-world performance. Such videos are 'entertainment' at best and not informative of any machine's capabilities, even though there's the appearance of loose correlation. It's unfortunate that despite everything out there to understand this, it's still underappreciated. Extreme initial mess concentrations need higher energies to remove quickly. We're moving to lower energies, meaning this kind of 'demonstration' will never yield good apparent results in the future. Real-world mess levels most respectable people would have in their homes can be exceptionally cleaned with very little energy. No one starts with a house full of stones and rocks, or tries to capture 30 days' worth of fine dust in 3 seconds that completely overwhelms separation systems. These videos simply represent someone 'playing in the dirt'.
The actual real-world failures of the V16 are not accurately captured from these videos. These videos are also contradictory: the first suggested good filtration, the second suggested bad (not that anyone noticed...). I'll show how the Gen5's performance can still be achieved with the V16 and, more importantly, why, for real-world mess levels. For the wrong reason, admittedly, it's nevertheless true Dyson shouldn't have released the V16 as they did. The problem seems to be suit-driven rather than the engineering.
