Compact model C2
louvac
A
Hi guys! Need help with my model C2. Apparently there must have been something thicker on the front end of the machine bag cover post because the cover doesn't want to stay closed. All there is now is a pin. I wound a rubber band and a twist tie to enlarge it and it seems to lock down properly.
Can anyone who has one tell me what was originally there? Thanks!
    1.7 MB
Thanks for that info! You may be on to something! I am going use the outer jacket of a round replacement cord along with the outer jacket of the black or white lead first in order to layer it. This should work or I may look at the local hardware store for that metal barrel. I have seen those! I will keep you posted! Thanks!
Louis
Thx Vaco......funny thing is the latch isn't bend or distorted. At least, I can't see anything wrong and I have a good eye! I will take your advise and try that!
Thanks!
Thanks guys! I tried everything. However, I do think there was something around the pin because there are some black marks as though something may have dry-rotted away. I will try to replace the latch and before I do I will attach the outer jacket of a replacement cord over the outer jacket of the copper wire cord and see if this works. Stay tuned!
Does it have a cloth bag with the rubber gasket? It even the rubber gasket is not there the top with not fasten tightly.
Antoine, not necessarily. If I remember correctly, wasn't the first Compact C2 model designed to be used with just the cloth bag? I think it was the next model that Interstate introduced the paper bag.
Louvac - look through the archives for old posts on the Compact, that will give you a clue as to what it was supposed to be like to begin with. Good luck rigging up a good solution :)
You know guys? I never thought about that! I should try to remove the paper bag and see if it latches without a problem. You all may be onto something here. I didn't think of that! Stay tuned. I love this machine so much! It's all machine and no BS! It reminds me of a jet with the open hole at the back which resembles the cone exhaust!
Had a similar issue with the C1 I had. There just isn't enough clearance on the lid for both the cloth and disposable bag, force them into place and you risk bending the latch.
My C2 came with an olive green canvas inner bag and a vintage paper bag. Lid closes just fine. If the cloth bag is not there the lid is loose.
I believe it is called a "Model 1", not a "C-1". I have one of those as well.
Oh you're correct it was just a model 1. You bought one off me not too long ago now. I did find it too tight with that bag and a disposable and had to bend the latch batch into place afterwards.
There should be a cloth bag with a rubber gasket that fits tightly around the bag compartment. You can also use a paper bag liner which acts as an extra filter and protects the paper bag. With that the lid should seal enough when latch the lid you
extra
extra
It has been my experience that without the cloth inner bag installed the lid latch is very loose. And obtw a modern Tristar inner bag fits the older models like the Model 1 and C2 for example in the event you want to use it and don't want to risk wearing the original green canvas inner bags they came with back then.
