Compact model C2
louvac
A
Hi guys! Need help with my model C2. Apparently there must have been something thicker on the front end of the machine bag cover post because the cover doesn't want to stay closed. All there is now is a pin. I wound a rubber band and a twist tie to enlarge it and it seems to lock down properly.
Can anyone who has one tell me what was originally there? Thanks!
    1.7 MB
Thanks for that info! You may be on to something! I am going use the outer jacket of a round replacement cord along with the outer jacket of the black or white lead first in order to layer it. This should work or I may look at the local hardware store for that metal barrel. I have seen those! I will keep you posted! Thanks!
Louis
Thx Vaco......funny thing is the latch isn't bend or distorted. At least, I can't see anything wrong and I have a good eye! I will take your advise and try that!
Thanks!
Thanks guys! I tried everything. However, I do think there was something around the pin because there are some black marks as though something may have dry-rotted away. I will try to replace the latch and before I do I will attach the outer jacket of a replacement cord over the outer jacket of the copper wire cord and see if this works. Stay tuned!
Does it have a cloth bag with the rubber gasket? It even the rubber gasket is not there the top with not fasten tightly.
