Obvious to all here I suspect.
1)
I've seen reference to "after market" drive belts being rubbish. What's a good (cheap!) source of Hoover (or other good) drive belts?
2)
I would like to replace the flex. Looks like a simple job. A 400/600 watt motor has a peak current of 2.5 amps. What rate cable should I get? 2 amp and 6 amp see standard sizes, so I'm guessing 6 amp (0.75mm area)
I note the external diameter of the original cable is 6.3mm and this has to go through a fixture on the handle, so the replacement cable must not be bigger than this.
Any advice welcomed.
BugBear
1)
2)
BugBear
