2011 Sebo X1.1
Some very interesting points Emma, great video!
I agree about the wand. I have an additional extension tube for mine that I put straight onto the end of the hose cuff. It doesn't have the chunky handle on the end of it, so it's much easier to use. When I'm doing the stairs or the sofa, I use the tools straight onto the end of cuff. The one thing I do like about the wand is that it's handy for quick pick ups. For example, when you're vacuuming the carpet and you see some crumbs under something or in a corner, you can whip the wand out quickly, without even putting the vacuum upright, and get into tight spaces.
I also agree about the hose, I do wish Sebo would add a full stair stretch hose, so there'd be no need for the extension hose, but at least the option is there for the extension hose.
Personally, I'd like to see Sebo introduce an entry model with manual height adjustment, the basic tools and hose and then have the Automatic machines as the higher end, with a stretch hose onboard and additional tools.
There will only be an argument if someone makes one. So far, this is a perfectly reasonable, calm discussion of both positives and negatives of a cleaner. Just as it should be. Everything has it's pro's and con's, it's interesting to see that discussed on a mature, rational level.
I suggest if anyone starts getting argumentative, we ignore it.
Red X4 in the UK - yes.
Actually Chris, not quite true on the red X4. The red X4 was an online special from 2012 in the UK, as was the white and yellow X4 from 2009 (that I nearly bought) which was available on Amazon UK.
I can't remember the white and yellow X4 model number, sadly but the 90559GB appears to still be on sale at a number of UK companies.
http://www.appliancespares-direct.co.uk/sebo-90559gb-vacuum-cleaner-red-p-8354.html
There was also the X1.1 in blue and dark grey that I owned - that appears to be an early Euronics special before the red X1.1
Here's the dark blue X1.1, or rather a stock photo of it with the wand facing the wrong way!
Nice video though, Emma.
About the X wand though - it was designed to be walked around with hence having the top grab wand at the top near the main handle to the upright. I agree that whilst it is bulky for the first time, you’ll soon get used to whipping it out and extending the hose via grabbing and pulling on the wand to get the reach or stretch going.
IN all nearly 20 years I have used the X1A, the T shaped tool has never come off due to the friction fit style of it onto the end of the wand. Neither does the stair cleaning turbo brush, when fitted.
I also have a straight suction tube, but it gets used with the Felix. I do agree regarding the longer hose - it would be appreciated, even if SEBO went as far to cutting the longer extension hose by at least half to compensate for something that could be stored on the machine but not get in the way. Perhaps that will come in time.
I've always found the agitation to be very good on the Sebo too. It doesn't make the dirt bounce like on an old Junior or Senior, but by modern standards, it's very good and enough to clean the floor perfectly.
Thank you.
I'll have to order one soon,because when I used my Sebo on the kitchen floor it was kicking back quite a bit.
@Everyone ~
Just in case anyone is interested again,I'm going to get my mum to try out my X1.1 I'll post on here what her thoughts are on it.
She better not scratch up my baby!😄 [this post was last edited: 9/6/2015-13:25]
Mothers Thoughts
She only used it briefly but here are her opinions ~
Likes ~ Auto height,how easy it is to use the tools,long cord,comfy handle,smooth switch,two recline options,looks nice.
Nit picking things ~
A bit too tall (she's only 5' bless 😂)
A little Loud for her likening.
Dislikes ~
None.
