1938 hover 300 shaft pulley
Concord NH
Question is this pulley shaft nub broke offy 300. It looks like this shaft is seperate and would unscrew separate from the motor. i want to ask before I try to unscrew it. I def need a new one if anyone has one it's about an inch and a half long unbroken. I have a 700 motor but it's tototally different underneath. Any belp.would be great amd if this comes off. Thanks. Matt
Yes it is threaded on, so you can spin it off. I have seen this part break before too. hold the fan blade as you twist the belt pulley off. Whack the end of the broken pulley a couple times with a hammer before trying to remove it.
