Wanting to Test Vacuums
The weaknesses I can see are as follows:
  • No procedure and measurements outlined to ensure consistent initialisation
  • No discussion of the distribution and placement of dust within pile — “spread evenly” is extremely vague and far more needs to be considered
  • No discussion of the properties of the dust materials and learned explanation of why they’re representative of an environment the machines were designed for
  • No discussion of the important properties of the carpet
  • No quantification of the cleaning speed and understanding why this is important, including overlap properties
  • No discussion of how to ensure accuracy of what’s measured and priming system to account for mass losses within the machine (dust sticking etc. and not being weighed)
  • No recognition, appreciation, or understand the statistical nature of particle removal from first order systems and how this is to be captured and correctly interpreted
  • No evidence of data reproducibility in any testing methodology, given all the above
Most people don’t have PhDs in experimentalism, so this is not surprising. Much of this is covered in my videos.
Even if you did all the above, without a laboratory and the necessary training, the results still have to be taken with a pinch of salt owing to lack of rigor that not using a laboratory brings.
@cheesewonton
The trend of the vacuum's removal quantity of (remaining) dirt per pass is not stochastic.
Agreed. That's not what it means though. See all evidence and explanations above as this is all fully addressed.
Now, I suppose technically if you want to analyse whether or not each individual particle of dirt is removed or not, I suppose you could stretch that into calling 'that' stochastic.
Individual particles are removed and some aren't. This is exactly what is meant by stochastic above. It is precisely mathematically modelled and empirically confirmed. There's literally no debate here and this is only revealing tremendous ignorance of well understood and solid science. Anyone who doubts this simply needs to go away, learn it all, and understand it. It has all been provided. If anyone here, of all places, thinks they know better, they'll carry no respect until they publish their findings like the actual scientists did and explain why they're contradicting them.
I challenge you to reconsider. If a particle is not picked on the first pass, is it:
1. More probable to be picked up on subsequent passes
2. Less probable to be picked up on subsequent passes
3. Same probability to be picked up on subsequent passes
As we’ve already agreed upon the answer is “2,” less probable. This means by definition the behavior is not stochastic; ie randomly determined.
You can determine this mathematically from the verified models provided above if you truly care. I recommend understanding it all if that's your goal. You clearly currently don't understand what stochastic means and the models provided for you.
“Verified” by whom?
What “models?”
Here you stated the problems.
To distribute dust you can use a flour sifter ( the type with a pull trigger that is used in dusting a cake in icing sugar.) and count how many times you pull the trigger. This allows you to pull the trigger and release to evenly cover the rug. 50 grams of dirt is about right for a 4x4 foot rug. In a home you usually encounter dust, grit, fluff and larger debris. Dust and grit is replicated by a mix of equal parts flour, baking soda and fine sand. Fluff is replicated by kpok, which is spread by holding a large clump and holding it about a centimetre above the carpet and letting it stick how it wishes. larger debris can be replicated by holding about 100 grams of clean cat litter in your hand and holding MOST but NOT all and throwing it randomly over the rug. I haven't measured how fast I move the vacuum across the rug. You could take the size of the rug and time how long it takes to do 100 passes figure that out and then calculate the average speed based on that. I vacuum in a w being straight forward diagonal back and repeat. Overlapping 50% is my standard. If I understand your second to last point correctly, science and theory has no effect on a practical test other than the hypotheses. This is why we test, to avoid unknowns and practically prove them correct or incorrect. To account for particle sticking etc you simply weigh the whole machine before and after. weighing the carpet proves what goes in and out. Hence the record keeping. The important properties of the carpet are as follows: two pile, This is tricky for vacuums as there is a loose tall pile of handle then also a very denso short pile bellow. This makes cleaning extremely difficult. Wool loop pile, wool loop pile carpet is great for creating traps and block as it is very densely made. Dust in the centre of a loop is difficult to clean!. ZSolution dyed nylon is great to represent a typical average carpet. Mohawk carpet is great for representing thedeeper piles that trap dirt. an area the size of a bottle cap can hold up to roughly 2-3 teaspoons of dust without looking terrible. Hence it is terrible to fully clean and know it is clean.
Here I responded with corrections to my method, then you quote your earlier reply that needs updating.
Again, wrong. The rate of removal per pass is not random if the test procedure is correctly accomplished. The rate of removal should be a line of decreasing slope. That is not what you get with a random distribution.
The trend of the vacuum's removal quantity of (remaining) dirt per pass is not stochastic. If it was stochastic each pass would randomly remove more, less, or the same amount of dirt, instead of a predictable regression. Variance doesn't make it stochastic.
It cannot be both stochastic, and the below:
Now, I suppose technically if you want to analyse whether or not each individual particle of dirt is removed or not, I suppose you could stretch that into calling 'that' stochastic. But even that is a stretch, because we already know (ahem) that if it not picked up on the first pass, its chances to get picked up on each proceeding pass logarithmically regress.
Stochastic means random. There is nothing random about the rate of dust removal per pass. It is a negatively sloping curve. The first pass gets the most dirt, and each subsequent pass removes less. Nothing even a tiny bit random about that.
We're saying the same thing (its not stochastic)
That's right. All this is discussed above and links to the papers provided. I recommend you read to understand seeing as you're clearly not listening to me. It's amazing how you just aren't able to listen and read what's provided for you. It's so obvious where you're confused as well, but there's just no helping someone not interested in understanding what is being said.
Unfortunately, the reality is, I don't have time to play personal tutor. All the information required to do things well is available. It's down to you at this stage to do your own research, understand things, and make your best judgement. You may want to download the standards and study them. You might want to understand the background science. It's going to be tough without training. If you get it right, your data will be accepted, if not, it won't.
If you want to know how to do airflow tests the right way, VacLab is who you study. He knows what he is doing because he is a real engineer .
This has been widely debunked as a meaningful metric. Using vane anemometers in the way shown in the video is a hallmark of total lack of understanding of basic fluid dynamics and how these instruments work, as fully discussed here. Using a configuration like this is fraught with errors, as also discussed in that thread. Furthermore, this measurement is wholly irrelevant anyway and isn't representative of what needs to be considered, as discussed here and the associated links. It's pretty bad this kind of nonsense is still being linked to and reveals a lot of about the trustworthyness of the sources. Anyone who genuinely understands the science, and desires to, will eventually realise this from the material available now. Fortunately, most of the silent lurkers in this place aren't netted by the primitive tribalism, bad faith, and aggressive ignorance on display at times that otherwise sours a fairly decent forum resource.
I like that his method allows testing the interface between the cleaning head and surface being cleaned, instead of just the airflow and suction of the motor minus plumbing losses. I saw on another video that he taped the head to the box to get peak values, but I hope that he does unsealed tests too.
A few thoughts for improvement:
  1. Instead of having two different opening sizes, have one side carpeted and make a removable insert for when a different opening size is needed.
  2. Make sensor two holes on each side. One for the vacuum gauge, and one for the anemometer. Have a few different sized inserts for the anemometer hole to simulate different levels of restriction
  3. It would be interesting to see the effect that turbulence and uneven airflow have on the airflow numbers. I wouldn't expect there is much impact with his setup, but having a hole in the center brace and using the side opposite of the head for the airflow measurements could help if there is any issue.
Still, even without those changes, this is a perfectly valid comparative method for a few aspects of performance.
His method overestimates airflow at the nozzle
Vane anemometers don't inherently read high. Or are you referring to the effects of turbulence and uneven air flow I mentioned?
It would be overestimating the airflow because of using a vane type anemometer. Otherwise itis fine.
That is only part of it. To accurately determine airflow one needs to measure the velocity of the air in feet per minute and the diameter of the orifice where it enters the nozzle. This would be the diameter of the suction inlet. If it is square ( some are ) multiple length times the width in fractions of a foot to arrive at surface area in square feet. With the diameter one calculates the surface area of the orifice in square feet as pi times the diameter in fractions of a foot. You multiply the speed in fleet per minute times the surface area of the opening in square feet to arrive at airflow in cubic feet per minute. Then multiply that by 0.8, the rule of thumb adjustment that accounts for the fact that turbulent air in a tub is moving faster at the center where you are taking the airspeed measurement than it is at the walls, where airspeed can be close to zero due to the boundary layer that forms on the walls of a tube. The salient point is to measure airflow at the suction inlet.
Most of that is relevant for measuring just the motor performance and system restriction (which is an important metric), but what I was pointing out is that his setup gives some information about the interface between the cleaner head and the surface being cleaned.
I don't think the .8 multiplier is going to be quite right for his setup where his anemometer is more or less sealed to the opening through which airflow is being measured. The instrument itself will define the cross section in that case.
The airflow through the instrument is not constant in cross section. It is faster in the center of moving air column and slower towards the outer edges, and possibly zero at the walls due to boundary layer. The 0.8 factor is a rule of thumb used to estimate the overall speed of the column of moving air in turbulent airflow. This is something used by HVAC techs and refinery staff measuring the speed of a fluid like air or petroleum in a pipe. It equally applies to measuring airspeed in a hose or attachment end of a vacuum cleaner.
My criticism of the form of measurement shown is that it often shows a higher airflow value than the suction motor of the vacuum is rated for. I have seen Vacuum Wars post huge values for airflow for vacuums who's motors cannot begin to generate that much airflow at the nozzle. Just as I have seen some others even here post airflow numbers at the suction inlet of a canister vacuum that are higher than maximum rated airflow for the motor in the vacuum, based on the model number of the motor and the Ametek Performance Bulletin for that model motor. The way I do it gives lower and more realistic airflow values.
There's no need to quantify airflow at all, for the most part, and it should be done professionally using an orifice plate as discussed elsewhere if anyone wants to be taken seriously. Not a single 'enthusiast' has done it correctly that I've seen, and as professional engineers do in industry for example. That tells you everything you need to know about where you should NOT be looking for any advice. Everyone should understand all this by now since the resources are available to learn how these machines work, and it reveals a lot about where help simply can't be provided fruitfully anymore. I suspect the lurkers understand, and at 23k views, there are a lot of them on topics of interest to them.
While I don’t necessarily disagree with your premise (properly measuring airflow is difficult) Your “resource” is not the ultimate authority on the matter.
Airflow is very important by definition of how vacuums work. No airflow = no cleaning ability. The rub is the airflow only truly matters at the physical point of cleaning; ie where the airflow communicates directly with the dirt.
I do agree at the hobbyist level these tests have limited (but not zero) value.
The other thing (for the audience) is if you know orifice size and pressure differential, you can mathematically determine the flow.
You are correct that airflow though the instrument is not constant along the cross section, but the tool should be calibrated to account for that.
I don't really know what that really means, but understanding my resource fully allows you to understand all things about these machines. To me, that, practically speaking, is fairly ultimate for all intents and purposes. There is no other resource I'm aware of that fully covers all the relevant core science—I know, I looked hard all over and was disappointed by what I saw...or didn't see.
While true, this is such a trivial statement, though, since it implies that therefore volumetric airflow magnitude above zero and its quantification is relevant to carpet cleaning performance, which is nonsense, as anyone who understands the science of these machines will know (knowledge being freely available from my 'not-so-ultimate' resource).
Airflow quantification (under two relevant conditions) tells you half of what you need to determine the motor airwatts of a given product. That's it. And too many people don't even understand the limited relevance of airwatts... Carpet cleaning capability is unrelated to the magnitude of above-zero volumetric airflow—which is why seeing 'enthusiasts' fixating on them is gobsmacking—and airwatts are relevant on carpet only under certain conditions.
It means circular references to your own un-cited, often incomplete and/or inaccurate claims does not “settle” anything.
I'll leave you to evidence the details and specifics of this convincingly (it never happens with this type of cookie-cutter response). It's too easy to play cosmetic contrarian. I provide evidence, then cite it—because that's why I provided it, then you claim I can't credibly cite my evidence for <no reason stated>. Absurd logic. Then you claim there are inaccurate claims, yet evidence none. If only you had credibility to lose after hollow smear comments like this.
