Your Dream Vacuum Cleaner...
My Dream vac would be EXPENSIVE!
A Kirby Sentria style vac with an led backlit lcd that displays belt condition, bag fill, brushroll condition, current motor speed, height setting, and "mode"(canister, shampooer, etc) touch sensitive buttons on the handle, laser headlight (bmw made them, why not?)tech drive with a digital motor ,and a carbon fiber fan spun by an 7 amp digital motor.
The Kirby Model C was my dream machine. But I have one now. So the next ones in line for me would be the Kirby Model R, American Lincoln Super Sweep, Kirby ComVac 1300 & 1600, the Aerus Lux Guardian Platinum, and the Rainbow E2 Black.
My dream vacuum
I have many favorite vacuums and this is by no means all of them
But If I had to pick a dream vacuum
It would be either a top of the range MD Silentmaster or a Lindhaus HF6
Depending if a central vacuum install is possible or not
My dream vacuum
My dream vacuum would be a central vacuum system with 2 large commercial style Ametek Lamb or Spencer-style vacuum pump motors for increased suction and airflow, 85 gauge American stainless-steel construction, an LCD screen showing the time, date, motor condition, and bag check indicator, dual exhaust ports, a utility inlet, high quality crushproof hose for durability, and better airflow, a stainless-steel telescoping wand, a retractable hose system, and automatic dustpan, high quality tools, including an upholstery tool, a mini electric power nozzle with an LED headlight, a a floor tool, a turbo tool for vacuuming pet hair of of furniture, a ceiling fan tool, a blind tool, and a choice of either an electric or turbine power head.
Reply #39
Then you'd want to look into either a MD SilentMaster S900r/S900r2 or the MD Modern Day M965h/M965h2. But out of curiosity, why would you want a smart screen on the power unit? That would totally decrease the reliability. Not to mention the price. MD has a proven track record because one of the reasons is that their units are simple. Otherwise you'd want to look into a Beam Alliance unit if you want the fancy stuff because those units have the screen that you want to have on the power unit. Our friend Owen here can show you the inside of those units, you may think twice after seeing it. But it is your dream vacuum and I'd rather not squash it. Everything else you can pretty much already get. At least the mini electric nozzle you can strap an LED flashlight on and call it good.
Anyways, my dream vacuum would be for SEBO to make these Kenmore Professional 12 and/or 15 models again. These were in my opinion the best overall portables or at least uprights that Sears ever sold. And as a die hard Kenmore fan myself for all of eternity, these are what I would own to use for myself personally.
I would have a central vacuum, DIY style. It would have to be my tellus "blue boy" unit modified to have 3x ametek lamb 122559s in air parallel. I would put a small bucket over each motor with holes drilled in it for sound deadening.It has a thick cotton bag with a MD Hyperflo bag inside. I want 4 inch pipes in the wall to allow for the massive CFM. 2 inch hoses with 3d printed inlets and ends to keep the CFM. I want a custom powerhead ( ideally) that has 2 rows of stiff brushes with one row of beater bars, a swivel neck, a dirt sensor (for fun), harsh chevron brushes, a cogged belt, 300 watt motor, clear window above the brush, extra bright led headlight and a 50mm neck fitting. I would have a spot in the laundry, walk in pantry, garage and the workshop. I would have a vacpan in the same areas as well as by the cat litter box. I would also have full hide-a-hose coverage for convenience. I Would have 2 motors on one circuit board and another circuit board controlling the third one, this way I can have different amounts of motors running in different use cases.
Mine is similar to @centralsweeper63
Severely overbuilt central unit, (might as well copy his) dirt sensor added on, chameleon hidden hose system, dedicated garage and kitchen ports, Lindhaus L-ion brush heads (one per floor) No cyclone for me though, one less thing to maintain.
