Vorwerk VK116 ET4 Mighty Maid
columbus
South-Africa
Herewith the photos of the mighty maid as it was known in South-Africa.
Although this is a VK116 ET4 Type 26 in essence of the late 60's the red version the mighty maid, was sold along side the following et10 et 20 VK117. At least that was in South African markets.
The original type 26 Vk116 et4 had a metal fan, as well as a metal cooling fan and at a whopping 200 Watts, this commercial stick, fitted with bushes top and bottom of the suction motor, did not live for 40/50 years. In that instance the machine would start with a whistle like sound and staggeringly become worse with time.
Yes, I guess the bushes could be replaced, leaving you with the same incounterment in the not to distant future. The weight of all the metal fans was a step for improvement.
Here the models prior to the VK 117 et10, and also the first introduction of the VK 117/ ET 10 had the metal structure in the top motor.
Haven said that, the mighty maid as in the pic, with the striking red colour, was introduced with a Teflon, suction fan, and a nylon enhanced cooling fan. This did away with the metal fans, decreasing the weight and increasing the speed, giving carbon brushes a longer life. The cord guide on top of the handle was not the push button as up to the VK117/ ET10, but as the later versions of the VK117 ET10 and further models where the cord simply slide in. The cord hook was also turned on the top and no longer as previous and early V117 models on the bottom hook.
The ET4 attachment carpet electro head, has 2 carpet height adjustments, which unfortunately became a bit technical, involving taking off the cover plate, and turning the bush end caps sliding it back into its slide. It only has 2 settings, One and two, and your discretion would lead you to see that the brush roll protrude at least the 2 mm for cleaning the carpet pile
drive belts was a slight problem, hence WHEN SWITCHING ON THE MACHINE, THE DRIVEBELTS STRETCHED IN ORDER TO GET THE BRUSH ROLL TURNING THROUGH THE PILE OF THE CARPET.
I love this little machine hence always had one around growing up in the family. Being compact enough it reached everywhere, under low based furniture and then the accessory kit which was pretty more basic to the beige and green Vorwerks manufactured, but in essence did the same job of suction, blowing and the electro brush roll.
I have noticed that Vorwerk/ kobold is Tommy's forte in Milan, hence here goes.
Many many Thanks
Adrian
Identi Plate on VK116-
I have same difficulties with uploading the pix, and saw in the other threads I posted some pix were duplicated and others did not post.
Matching floor & carpet nozzle for it
As it is so rare I'd rather offer it here to fit a real RED Vorwerk before it goes to the usual auction sites.
Actually it came with a red wet & dry shop vac by Vorwerk, but it will fit all Mighty Maids and Advance machines (preferably red gray color scheme). The regular green version was sold with all uprights 116 and 117 and with the 240 canister.
Any offers?
Hello Adrian, very nice and rare find! I had never seen one like that, obviously Advance never released Mighty Maids in Italy as "vorwerk folletto" has always had the exclusive for vorwerk kobold sales. A few years ago i found a red vorwerk vk 117 but sadly i realized it was a rebudged- red and grey painted kobold...all non visibile parts were actually ivory or green! The look is great but, as a vorwerk fan and collector, it's very hard for me to see sonething not in the ivory/green suite! However I posted the scans of the corresponding vorwerk kobold model, I try to post the link! Enjoy your Mighty maid! Tommaso
http://www.vacuumland.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?17134
Mazeltov, WOW
Dear Tommy-
In my search on information on the ET20 power head, I now saw your response to the subject VK 116 ET 4.
You have an amazing collection, any collector's dream. From your pictures I can also see that you refurbish them with a fine sense of appreciation and perfection.
I recently spoke to the Vorwerk Kobold importer here in South-Africa in Randburg, who shared with me, Vorwerk Kobold sells more Vorwerk vacuum cleaners in Italy, than in Germany.
The latest machine is just to wonderful, and with a non carbon brush fitted motor and a 400Watt motor, still is a very powerful vacuum cleaner.
Thank you so much for your Vorwerk insert/ contributions in this blog. I get mesmerized in the old manuals you post. It is awesome.
Adrian
South-Africa
