Thoughts on the Dyson DC25.
I would happily throw my DC14 around and be confident it won't break :)
How many DC14's do you see with cracked plastics?
Owning both the dc25 and the dc41 I can tell you the dc25 has much stiffer bristles due to the fact that the packs in the dc25 are thicker in circumference,. Both clean well but I prefer the dc25. My only complaint about it is the bin capacity been too small. I would have liked a dc14 size bin on the dc25. Its ability to pick up pet hair and lift the carpet pile is fantastic.
One of my favorite machines.
I fought the DC 40 was your favourite anyone seen the performance on the DC 25 Rogers video
got to 25:41
Those videos don't really mean very much. Ask the question about the durbility after a few uses.
But if you want to see the videos of the older models, please see below. I see a DC24 on there. If this had been how the DC24 was tested then I wonder why the parts have broken over the years and the plastic seems thicker on the DC24 compared to what is available today.
http://https//www.youtube.com/watch?v=MW4zgTHr9zQ
Sounds like you're desperate for him to say that the DC41 cleans better. Why don't you ask Dyson for the test results data of the pick on the DC41 to confirm?
Super sweeper
When we first got the dc 14 to sell I did drop a brand new one off the mezzanine ( a standard story high )  in my workshop, The cleaner head bent upwards from the impact and the two plastic sir clips shot off ( one yet to be found) but a few minutes of disassembling and it worked perfect again.
A year ago I knocked off ( buy accident )a traded in Ultimate G  , It hit the ground like a tank, Bits shot off in every direction, The wheels broke, the cleaner head mounts and lever broke off, The chassis cracked the head light unit got hit by the cleaner head and it bent and broke.
Does this make the Kirby a weakly built machine. No not at all but it goes to show how unfair doing that test with these two machines would be.
A kirby ways a ton and its own weight was its biggest failure in this instance. It meant the machine hit the ground with more force putting greater force on the parts. Cast aluminium is very strong for every day bumps and knocks but it has no give to it. Hot it too hard and it will break. Why do you think modern car bumpers are made from plastic, It can absorb light dings and dents.
For a throwing off the roof test to be fair you would need to similar weighted machines again made out of similar materials.
Just out of interest the Kirby also smashed out a fist size chunk out of the concreate floor it hit so hard. My Two technicians almost jumped out of their skin
Sounds scary, Gareth. I dare you to drop one of the newer, cheaper Dysons
The Ultimate G is a tank. I wouldn't use it for testing and I honestly wouldn't use it daily in my house.
Perhaps the being-mowed-down-by-a-Plymouth-Fury-at-40-miles-an-hour test will be more fair, we'll see.
I wouldn't want to do that to a Plymouth fury you might scrape the paint or something.
I was doing some training  with some stores and threw a dc37 down a flight of concrete stairs , scratched a bit but not broken at all.
I don't really think that you will see dc25's in daily use in 20 years time
because the cleaner head motor goes
Heres one--How 'bout the RL trash truck crush test!!!Bet NO vacuum made would pass that-esp if you put the vacuum under the edge of the packer blade and lowered it!On the "Classic Refuse Trucks" videos they show some sadly vacuums being crushed in trash trucks-one video showed a bagless Eureka upright getting crushed several times in a SL trash truck.I think THAT wld be the untimate toughness test!If any vacuum cleaner can withstand those tests I would buy it!
How about a fire test? a DC25 overdrive passed that successfully twice! Then got smashed up with some perseverance
You're telling me somebody set a Dyson on fire, and it survived, nonsense. Plastic melts, and fire causes melting. it's like saying ice doesn't melt when you throw it in a science oven. The Dyson would've smoked, and emit a crap-ton of pollution.
