shrink1982
Active member
I have noticed on my Maytag 1200 the suctions through the hose is not all that great. Once I extend the wand and and add the dusting brush I can definitely tell the difference. The suction just isn't on par with my Sebo D4 premium. In fact, the suction is about as good as the suction I get if I hook the hose up to a Kirby, which seems odd considering it has direct suction only. I am not sure if the Maytag underperforms on suction only because the wattage of the machine is split between the two motors resulting in a much less powerful suction motor than what you get on a machine that only has a suction motor. I am not an engineer I just know what my experience has been. I have also noted that the part of the hose that clips into the hose handle, there is a slight leak of air. It is very subtle but I can feel it. It isn't sealed well but I don't blame that for the performance as it is very minimal. I think the suction motor is underpowered. It would be nice if the suction motor would pull more electricity and speed up when the direct air motor and brush roll are turned off. Has only else noticed this on Tacony models with TandemAir?
