You folks are continually amazing
OK, many pics!
I think I'm being convinced to buy a new Aerus/Electrolux rubber hose. There's a tiny bit of play in the junction between my generic hose and the main unit so that when I actively push it in, the suction is slightly stronger. I'd like better precision in the seal for that suction.
Except for the hose, and maybe the long beige sleeve (that's the close-up, pic #2), I think I'm all genuine here.
But will you indulge me a couple more observations, about which I'd treasure your expert opinions?
**The Off/On/Reset switch on the power nozzle is hard to operate. I don't know that I'll ever need to actually, even with a genuine, switchless, hose.
**The Cleaning Selector on the main unit is supposed to rotate from 1 to 6, right? Some part of mine is offset by about 1, so that the range is from 2, past 6, to 1 (2, 3, 4, 5, 6, 1). But I've never seen this have any affect. Does it have something to do with adjusting the trigger for popping open the bag door?
**Finally, the motor will age, slowly, or eventually, right? Is there a metric I can use to know when to replace the motor?
Thanks so much, kind people.
