SEBO vacuums are great and the belt breaking is unlikely to happen. Not a fan of the X series due to the way they look, the brush cannot be turned off and I prefer the Felix as it's more versatile and looks better in my opinion. Never seen a broken belt on a Felix.
It's not hard to change the belt on the X series - I have done it. It does not take half an hour, that's an exaggeration! I think we need to note that it's unlikely that this needs to be done unless there's a fault with the machine!! Once the belt has been obtained, I suggest checking that that servo motor is functioning and lifting the head up and down. Failure of the servo motor can cause strain on the brush drive and breakage of the belt. Again this is rare.
It's pretty clever how these machines go together and take apart just as easily. That computer system may not be everyone's cup of tea, but it certainly is very clever stuff. A vacuum cleaner that tells you it's going up or down, that's it's brush is worn out and even shuts itself down if there is a blockage and allows for immediate use once the blockage has been cleared. Is very unique. Also don't forget that the handle comes away with the power cord for easy replacement if you run over the cord or damage it another way.
