Sebo X4 brushroll not turning.
hi-loswitch98
Hi I've had my X4 back that I bought in 2013 off a carboot, I sold it to my mums friend & now she's given it me back to clean for her. I've noticed that the brushroll wasn't spinning during use, I thought it might have been because loads of hair was wrapped around the brushroll but it's the same after the hair has been removed.
Would anyone be able to diagnose this for me?
Thanks 😊
I've checked for clogs & unless the brushroll has broken then I'm unsure really. I'll try to see if the belt is off tonight.
Yes, the second belt had sheared off. The other one was fine though.
Which belt is which because they have a primary & secondary one. I'm guessing the one I need is the secondary one as it goes to the brushroll cover.
Thanks sebo_fan, I was wondering which belt it was. Just found out the X4 was made in 2006 & this is it's first belt change.
Well who the hell vacuums up glass, coins, marbles and bolts?!?!
I have had the same belt on my Hoover Turbopower 1 U2194 since I got it in early 2012 when I cleaned it up, I had that cleaner out the other day and the brushroll is still turning fine!
I got a new in box Hoover Purepower manufactured in 1999, the belt still turns the brushroll fine, it could benefit from a new belt but it turns the brushroll perfectly adequately.
Ive had the same belt on my...
And?
Alex I do wish you'd stop being so anti-SEBO.
This thread was started by HI/LO who wanted to know if anyone could diagnose the problem for his SEBO X4.
"...I got a new in box Hoover Purepower manufactured in 1999, the belt still turns the brushroll fine..."
Yes. No wonder the original is intact. It clearly hasn't been used on a daily basis since it is "still in a box"
I've had the same belt on my X4 for 10 years since it was bought brand new in 2004. The model is now with my neighbour down the road. She's still on the same belts.
And for your information, due to her poor eyesight and being a new Grandma, the odd marble and odd piece of lego often gets sucked up the SEBO. Her husband adores the upright because it can clean the carpet in his workshop which often has loose screws, wood shavings and stuff I wouldn't dream of driving a non-commercially based upright vacuum through.
Agree with Nar on this one, my friend's folks have had an X1 in daily use since 1998 and it's never had or needed a new belt. Infact, it's had a complete brushroll replacement and still doesn't need a new belt.
The 2 belt system in the Sebo is not dissimilar to the 2 belts on the Hoover Turbomaster.
I have never had any belt problems with Sebo vacs, but regular flat belts do stretch and snap after a while. My Turbopower 2 seems to suffer from the stretched belt syndrome more than any other upright I've owned and while the brushes still rotate, you can hear the activator slowing down on carpet when the belt has lost its tension.
A Turbopower 2 with the original activator and a toothed belt would be fantastic.
I never said flat belts were better, I was saying that it was easier to change a flat belt on an ordinary machine that faffing about with the Sebo trying to change the belt.
Roger I agree, the Turbopower 2 belts stretch fairly quickly and cause the brushroll to spin slowly.
Not much difference really compared to having to undo a few screws on the bottom of a base soleplate of most uprights to gain access to the belt.
Only one that has ever been easy to remove in my experience and it has been the old LG bagged uprights - had a simple slider that unlocked the sole plate from the machine for access to the belt.
Well most vacuums you undo two, three or four screws but they was at least 8 screws and bits and bobs that have to come off to access the belts on the Sebo, true though that it will last AGES but what I am saying is, when it comes time to change it, it is fiddly!
I've seen the Espares video and it looks quite straight forward and you probably wont have to change the belts for around 10yrs so it's not a problem. Working on vacuum cleaners is FUN! :)
It is easy to do yes, but it takes to long for just a belt change, much longer than a flat belt cleaner on a regular machine.
nobody wants to be spending like half an hour changing a belt, granted they would not need to be changed as often, if ever.
SEBO vacuums are great and the belt breaking is unlikely to happen. Not a fan of the X series due to the way they look, the brush cannot be turned off and I prefer the Felix as it's more versatile and looks better in my opinion. Never seen a broken belt on a Felix.
It's not hard to change the belt on the X series - I have done it. It does not take half an hour, that's an exaggeration! I think we need to note that it's unlikely that this needs to be done unless there's a fault with the machine!! Once the belt has been obtained, I suggest checking that that servo motor is functioning and lifting the head up and down. Failure of the servo motor can cause strain on the brush drive and breakage of the belt. Again this is rare.
It's pretty clever how these machines go together and take apart just as easily. That computer system may not be everyone's cup of tea, but it certainly is very clever stuff. A vacuum cleaner that tells you it's going up or down, that's it's brush is worn out and even shuts itself down if there is a blockage and allows for immediate use once the blockage has been cleared. Is very unique. Also don't forget that the handle comes away with the power cord for easy replacement if you run over the cord or damage it another way.
