Regina Electrik Broom
Regina Broom
This I believe is a 1968-69 model mid range two speed high performance series broom as noted by the rather high 5.7 amp rating. Most of the regular series models were on the 2.5-3 amp range. I have basically the same broom but instead of being a model
B815TG mine is a B815TD with the only real difference being a slightly older motor housing. Does yours by chance have a slide switch or the old metal pole switch that goes up for low speed and down for high and in the middle for off?
