Well, I managed to cut the piece of metal at the top (with the hole in it) to the right size on one for the spade to slot into it but on the other I accidentally cut too much off so that's that buggered.
When I was cutting them apart though I noticed that above the fork that goes into the terminal on the motor there are... Guides ? Would that be the right word ? For the bare wire to "slot in" for soldering to the terminals.
I do believe in later years you yourself Benny said that they soldered the cables on instead of using the spade adapters, so that "figures" with the motor being from '99.
I guess I'll have to buy myself a soldering iron then and solder the wires on ?
But before I do that, I want to know if it will work in the end, since I'm a tightwad Scot and don't want to (can't afford even) to throw money at things that won't prove fruitful.
Then again, I could be completely wrong about them having to be soldered, check the picture for reference and see if you can spot what I'm seeing.
