Nice Electrolux Model E Found!
electrolux137
Los Angeles
In my quest for a Kirby D50 headlight cover, one of the places I went was my friend's vac shop here in L.A. He didn't have a D50 but did have something else for me! He said, "There's an old Lux up there we took in on trade. You can have it if you want it."
I went up to their vac graveyard and there sat a fairly nice Electrolux Model E. It's a big scuffed up but I've seen a lot worse -- and there are no dents. I plugged it in and turned it on and the motor purred just as nice and sweet as could be!
I brought it home and opened the front cover and saw that it had a cloth bag in it. The bag was very clean - spotless, in fact. So whoever owned the machine took care of keeping the bag clean.
Then I took off the back cover and saw it still had a filter back there! That's something you hardly ever run across any more because when the Model F came out, Electrolux told people to remove the filter and replace it with a cardboard gasket (to make the rear cover sit snugly) -- the filter was no longer needed due to the multi-layer dust bag.
The only downside to removing the filter is that the machines are quite a bit noisier without it. But the suction is slightly improved and the motor doesn't heat up as much.
As you can see, this filter is pretty dirty. I wonder if it was ever replaced!
lovely!
What was it traded in for, if you know?
Kevin,
The cardboard replacement gasket was to keep the rear cover from rattling and fill the space where the filter was.
Tom
