My GPO Rotary Telephone Collection
Two older Trimlines with the larger 212 handset plugs different from the modern modular plugs. The line cord is also the larger 212 into the phone. The blue one has suffered some major fading/discoloring---however true to form with Western Electric/AT&T, it works just great!
That's a sweet collection, Charlie
I'm glad you mentioned the larger modular, handset cord.  I remember discovering them, years ago, but not understanding how to remove them. It was apparently just for ease of manufacturing that they made them modular.  Then they later discovered they could make the cords removable and save even more resources.
Those all look great !
I got myself another GPO 746 in Topaz Yellow.
This one is Brandnew and never used, it was rented out from the post office in 1978, but never got connected and remained in someones loft ever since.
I converted it with the new BT plug and moved about some of the internals to accomidate the modern BT system.
This first pic is a before photo, see, had the original line cord with the GPO terminal block.
No, it is an entire new line cord in the original matching colour (yep, you can still get hold of all the colours!) with BT plug already fitted, all that has to be done with the wiring is as follows...
Remove the strap between T4 and T5 and replace it with that 3.3k resistor, remove the strap between T6 and T7.
Then remove the strap between T8 and T9 and insert inbetween T17 and T18. Replace the line cord with the new BT plug type and that is it, converted.
The rectifier between T1 and T2 should already be fitted but I changed it out for new one incase it has degraded over time, which is why it looks different on this pic...Anyway, this is what an unconverted phone looks like (how it was originally) and if you compare it to the other pic of the wiring I posted, you can see what has been moved about. 😊
Just as a note "T" means Terminal and all the terminals are numbered from left to right...Top row, T1-T9 and bottom row T10-T19
Actually those Princess phones were available in the UK. Wild n Wolf have also done similar ones but not half as good quality.
When I was growing up my parents had Trimphones, including the garish one in leatherette. Here's the Wild n Wolf Princess
Wild n Wolf also brought out a repo Trimphone a few years ago. I have a white one.
http://https//www.amazon.co.uk/Wild-Wolf-Princess-Telephone-Cream/dp/B001LM5XBW
That is a replica princess phone, not a Western Electric, the original princess phone was never sold, or should I say, rented, in the UK.
What we had that was similar, was the GPO Trimphone. We never got the Trimline phones either, we did get varients of them in the late 80s and 90s.
BT Snoopy And The Woodstock rotary dial telephone...This was a part of the BT "Telephone Special Range" which I believe the TRS range came out in 1978...This Snoopy phone is a little later, from 1981.
finally (for now) my Trimline based phone...
My BT Minstrel 5011 Slimline telephone, incidentally, this was the same phone Hyacinth had in "Keeping Up Appearances" in Series 1...She had the Minstrel plus in Series 2 and then a different one for the rest of the series, not sure what that was though, but this was her original phone (bellow) only, Hyacinth had it in "pearl white" and not "Coral pink".
