Enter the model numbers in Sears Parts Direct and see what the part number is for each model's motor.Are the motors for Kenmore canister vacuums 11626212601 and 11626212602 interchangeable? Thank you for your assistance
While the vacuum bodies are identical other than their color, the motors are different and they use different rubber mounts between the fan case and the body. The rear mount is the same for both however. Looking at the diagrams and images in Sears Parts Direct that first model number uses a Panasonic motor and the second one uses a Cinderson motor.Are the motors for Kenmore canister vacuums 11626212601 and 11626212602 interchangeable? Thank you for your assistance
