Electrolux Epic 6500 SR Motor Replacement
jshoe
MA
My main vacuum is going to need a motor replacement soon. It is an Electrolux Epic 6500 SR (the blue and gray model).
What motor did it come with and how many air watts is it?
What is the proper replacement motor and how many air watts is that?
Any good replacement videos out there? Thanks
The old Electrolux motor factory was sold to the employees and is now known as Electromotor Inc. They sell two drop in replacement motors for the Epic 6500 SR. One has flat fans and makes a lot less power than the original Renaissance motor in your Epic. That motor is 6500-293 and is the one most vac shops try to sell you because it is less expensive. DO NOT BUY 6500-293. The other motor is a two stage motor with a tapered fan just like your original motor, but makes another 100 + peak air watts over the original motor. That motor is Electromotor 6500-298. It is a drop in replacement for the motor you have now. You do have to remove one carbon brush to get it to slide into the mounting ring but that is not a big deal or what I did was to file shallow notches on the inside diameter of the mounting ring to clear the brushes. The brushes are just a tiny bit wider than those in the original motor but the rest of the dimensions are the same. I put one of these in my Epic 8000 that came with the same motor that is in your Epic 5600 SR and it literally doubled the measured airflow at the hose end. Your original motor, if it's 650-242, has 349 peak air watts. It it an earlier motor, 6500-274 it only has 320 peak air watts and the cheap replacement motor 6500-293 only has 285 peak air watts. 6500-298 has 438 peak air watts. That's the one to buy.
A good place to buy a 6500-298 is Lighthouse Motors in Arizona. They have the lowest prices. On their website they call the motor 6500-242UP because it is the upgrade for the 6500-242 that is probably in your Epic. Confusing I know. You can call them and specify you want 6500-298. They are nice people too. Their website is kind of cluttered and confusing. They don't often respond to emails but they do answer the phone.
https://www.centralvacuummotor.com/lighthouse.htm#gsc.tab=0
I appreciate the reply. It doesn't look like they have that motor online, but I will give them a call. You said thats a direct drop in replacement for my motor but I need to move some sort of carbon brush? What is that and is it hard to do?No other changes needed on my machine? Thanks!
They call it their "6500-242UP" with the UP standing for upgrade. 6500-298 is the upgrade for 6500-242. Better yet, just call and order over the phone so you know you are getting the right motor. They are nice people to deal with and their prices are unbeatable.
I just received confirmation from Dennis Manci, the Pres of Electromotor that "The 65000-298 motors are wound, assembled, run in and tested in our Tennessee factory."
Cheesewonton, that is NOT the case! Electromotor VERY CLEARLY states on their site that the motors are "made in the USA with globally sourced components" , meaning most likely Chinese components with final assembly at Piney Flats, Tennessee.
I will call them. On the page you sent it lists the air watts as 258, yet when I click the details it lists it as over 400. Also, I won't need to make any modifications? Thanks for your help.
There is a mistake on their website. If you look on the listing there is a blue font, underscored link to a "Product Bulletin". Click on that. Don't click on the link above it. All that does is display an image of the motor. The lower link will load an excel spread sheet with the performance charts. Make sure it loads the chart for "LH6500-242UP" The first time I tried it loaded a performance bulletin for another motor. Their website is having problems so be patient but you can find the correct info from it.
Dude, Electromotor makes a lot of different motors. Many of their motors are indeed made in China or have Chinese assemblies. Their two stage motor for uprights is made in China. This motor is a legacy Electrolux design that is entirely US made.
I suppose it makes sense that their website is having difficulties. Where and how could i find their website?
This is a webpage from the website for Lighthouse Vacuum motors. They are a distributor in a small town in northern Arizona that sells pretty much the full line of Electromotor products. If you scroll all the way down on this page you see the far left column has a lot of images of vacuum motors, then way down it switches to carbon brushes. Two items up from the beginning of the carbon brushes you see a motor they call "6500-242 120 volt upgrade". That is what they call the Electromotor 6500-298, since it is the drop in replacement for the old Electrolux Guardian motor, 6500-242. In the next column over shaded in yellow are two underlined links in blue font. The upper link "LH6500-242up" is just a picture of the motor. The lower link "Product Bulletin" opens a spreadsheet that has the motor performance charts. Lighthouse is the least expensive place I have found that sells these motors. Only $119 plus shipping. They are straight shooters and pleasant to deal with. They are not good at responding to emails ( analog souls in a digital world ) but someone almost always answers the phone.
Btw, while the Lighthouse Vacuum Motors website is chaotic ( ! ) if you poke around you will find a lot of gems for very reasonable prices and some good information too.
Thanks.
