KIRBY AVALIR
Status
Not open for further replies.
I have had more than one Kirby salesman point out the Kirby appeals more to the MAN of the home than the woman.They mention the man of the house is more likely to close the sale.Men are more akin to the Kirby attachments-esp the Handi Butlers.Keep in mind there are other vacuums that women didn't like-Royal Powercast and Hoover Z.Both machines too heavy and clunky.And both of those you almost need your tractor or truck to push and carry them!At least the Kirby G machines move well with their Tech Drive.But indeed,heavy to lift and carry.Can you imagine the weight and "clunkyness" factor if the hose and tools were on board the Kirby as some want.You would need your truck to push it and your forklift to carry it up the stairs!
When will the Avalir be on the market?
When do you think someone could actually purchase a new Kirby Avalir? How long do you think the 100th Anniversary logo will remain on the machine? Just wondering what everybody thinks?
Alex
That's not a power nozzle in the patent drawing. If you read the description, that's the shampooer. That's why the hose has a cord on the outside, to power the motor that turns the shampooer brush. Having the shampooer on the end of the hose/wand does two things: Keeps the suds away from the rear wheels, where it can get into the transmission's gearing as well as allow for shampooing under things. The user controls the suds flow at the handle end of the hose.
Frkirby 560
I just got a reply from kirby, and they said it will go on sale in December. I would not be surprised if some distributors got them sooner.
Does anyone else think this is a Plan B machine because of problems with the newer model? I just dont see how they can spend all this time and only come up with a new shampoer. I think something went wrong and this was the back up plan. In which case some were at Kirby they are working very hard to finish the new one.I really hope this is the case.
I have worked full time in R&D for a few years and Now still do it on a consulting level. It may not even be a design of machine fault but a tooling issue. The amount of times I have worked on projects that have been delayed because of a tooling issue I cannot even count. I remember once a project been delayed for 3 years because of tooling issues. It sounds ridiculous but it happens more often than you think.
Kirby Avalir
Dan,
Not familiar with the 3G Series. What were the "tons of problems" that Kirby had with the it's 3G's?
Gareth
You're right....this could very well indeed be the case. But why would they introduce the Avalir then?? The Sentria II was only recently introduced, they could have just put a 100th Anniversary label on the Sentria II & move on. Seems rather hasty of Kirby to release a new model just for their anniversary. I just personally hope the concept Avalir never sees the light of day....it's too "weird" & far-out for Kirby in terms of design.
Kirbyloverdan - Ok, now this is the second time you have claimed the concept Kirby is out & being tested. Where is your proof?? I personally think you don't know what you're talking about & making things up! Show us some actual PROOF that what you say is true!
The G3 was the first G series Kirby. They were tereible by Kirby standards. The motors burnt out. The main motor plate bearing housing would shatter if you used it with the hose for too long. The powerdrives would pack up for refusing to go into neautral.The back wheel rubbers would shredd.
I have also gotten the distinct impression that this was not the machine that dealers were expecting. I was told on good authority that the new unit was lighter with major changes. When i called up my contact he just said yep sometimes things happen.
If you look at the patents online you will get a good idea of what the prototype looks like and its not what was launched.
You dont file patents for fun its expensive hugely time consuming. Their is a new kirby out there but its been held back for what ever reason. We can just wait and see
Kirby
As Dan stated the first version of anything can have problems that aren't quite worked out at introduction.And depending on the company the introduction can be scheduled by management looking at a calendar or engineering looking at real life testing.The problems I have seen on G-3s that were greatly improved later include---Weak handle spring,Clip at top of cloth bag breaking,First gray fan developing tiny cracks that doesn't happen with the white fan,Switch unit (on/off-hi/lo-and safety in a then new unit)not durable,Rubber cord discoloring and cracking.A G-3 with newer parts or the newer Generations can be an exellent vac for someone who understands it,has a lot of carpet and doesn't mind size and weight.
"being tested"-As I,Dan and others know vac(& other)companies test products in normal to extreme areas.Part of the testing involves secrecy!Especially with an all new model.Car companies have road tested new models with fake trim and fenders for example to make sure it is seen when they want it seen.Years ago we were told at Kirby that Mike Tysons huge home and the Rock & Roll Museum were cleaned with test Kirbys.Locally the Bristol VA Electrolux factory tested prototype Discoverys years ago including one with a foot pedal release that did not make regular production.A secret at the time but if you were here I can show you one for proof.
Tolivac-Good to know I'm not the only one who knows Rube Goldberg!
Kirby Avalir
Thanks Gareth and Jimmy.
I had no idea they had so many problems. It makes sense that Aerus is having problems with their new machines now and explains why (somewhat) why those new Hoovers I bought back in 2008 were such junk.
I guess they were bringing so many new models and styles on the market all the time that they had no time to really test the machines besides attempting to build the very cheapest product they could put on the discount and big box store shelves.
Makes me appreciate our old Electrolux 2100 EVEN if it does have a WAY TOO SHORT cord!
From what you are saying, I have been lucky with my Black Rainbow then as it was one of the very first off the line when the black Series came out. It gets used almost every day and the only repair has been where I damaged a spring on the hose coupling.
Unlike many collectors, which have many many vacuums sitting in boxes or only used once in a while, these 2 machines get heavy use all the time.
The only problem with the Electrolux in almost 14 years was the cord winder quit.
Before that I used a Kirby Legend ll for years and years and Tom Gasko replaced the fan one time for me. Before that I only had Air-Way and it never had any repairs. Still works fine.
Thanks for sharing the information.
Status
