Ohm Meter
You can test it with an Ohm or multimeter. If you use a multimeter, just set it to Ω (ohms) and touch each lead to the different field wires. If the needle goes all the way to the right, then you have good continuity. But if your armature is bad, chances are that the field won't be far behind.
