Kenmore Progressive thrift store find
macmansam
Minnesota
I've always wanted one of the new Kenmore Progressive canisters, but I thought it would be cheaper to keep an eye out for one in a thrift store. I found an older model for $9.99 and bought it right away. After that, I went sears to buy bags and filters. I was smart enough the take a picture of info plate on the bottom because I knew I wouldn't remember what model it was. The number is 29812990 and they couldn't find it listed in their look up flip parts book, so they asked me to bring in the old filthy filter that was left in it. I also wanted to get the newer power nozzle with dirt sensor but was told they only sell them online. I can't find them on the sears website anywhere. After all of that, I went home with some new bags. I put the power switch in the off position and plugged the vacuum in and it turned on. It will only shut off when it's unplugged. How can that be fixed and where can I get the new power nozzle for the current generation vacuums? I'll post some pictures too. I'm excited to restore this.
e bay has powerheads i got one for my kenmore mine is yellow and the main unit is black but i dont care. i dont care to much the ones that swivel they alway turn the other way for me
Looks like you got a good deal. That is a first generation Kenmore Progressive canister, maybe someone else can give the years it was made. And what the problem is with the switch. The exhaust filter on yours is a foam block (high efficiency filter), others used a pleated HEPA filter.
Sears did sell a version of that power nozzle with dirt finder during that time, which should work. The current Progressive power nozzles, however will not work on your machine as the hose and wand connections have changed.
Nice find there Sam! I bought one of these new for my parents circa 2000-2001. The model I bought them looked just like your's except their's had the dirt finder on the power nozzle. It also had the electronic controls on the handle. I thought that the electronic control might be a weak point & would probably be the first thing to have a problem if anything. Well they had it until the end of 2010 or so. No issues with the controls. One of the wheels came off the power nozzle & would not stay on, but other than that, it was a great vac.I believe the model I bought for them was just under $500, it was the TOL model at the time. My mom in fact gave it away to a newlywed couple that needed a vacuum. It might still be in use!
They then purchased another Kenmore canister, however sadly the quality of their current one is not the greatest. I also don't like some of the newer attachments on Kenmore vacs.
I know some of the progressives had circuit boards but this one most likely did not. That being said it is probably a bad switch inside the hose handle causing the suction unit to not turn off. My guess is that you will need a new hose. You can find one on eBay for around $50 new. Look for the metal chrome tip extending out of the plastic gas pump style handle. The handle can be just about any color but should only have 3 way control- off, suction only, suction and powerhead. Should be 3 prongs on swivel head that connects into canister base. You will notice Kenmores and Panasonics with 2 different style "gas pump" style handles with 3 way switch, either one should work on your Progressive.
This is probably around a 1999 model with that power head and it was the introductory series into the Kenmore Progressive. About a year and half ago I completely cleaned and refurbished a green colored one of these, unfortunately I had to scrap the powerhead, needed too many new parts and I got a great deal on a used one from my local vac shop. All of the parts on this machine are very similar to the current on the market Panasonic MC-CG902. See link. All current market Panasonic canisters have the power nozzle design that is found on your Progressive.
Currently on the market the only Kenmore canister with a dirt sensor is the red Progressive with the swivel power head. The wand connection on the swivel powerhead and the white, blueberry, and Intuition canisters is a different setup and will not fit your progressive. Only the Orange 2nd entry level Kenmore has the original CenTec design which would fit this. The power heads for the 2 entry level machines, White and BLueberry models are exactly the same except for wand connection. Lime green is manual cord and disconnect. Orange is original style toe operated quick disconnect. White and Blueberry are new style toe operated quick disconnect. eBay will have some most likely used nozzles.
Kenmore uses CenTec manufactured power nozzles on there vacuums. The vacuums are generally manufactured by Panasonic and branded for Kenmore. The powernozzle on your Progressive is Cen-Tec Quiet Drive CT18DXQD. http://www.centeccommercialvacuums.com/commercial-cleaning-items/CT18DXQD
http://shop.panasonic.com/shop/model/MC-CG902
Here is the Cen-Tec nozzle that you have mentioned you are looking to get. Both power nozzles are very similar. I'm fairly certain they are the same motor. Both use Serpentine belt, both have same 14" double brushed wooden Chevron agitator. Both have bristle up to both edge of nozzle- double edge cleaning. Note that neither one has a suction duct extending around the belt area to reach the far side of the nozzle. Dirt swept in that area has no where to go, a flaw that greatly angers me about CenTec nozzles. Both nozzles have the same carpet height adjustment and motor protection shutoff. I've noticed with these nozzles that if something gets stuck in them it takes the sensor a good bit to react and shut down the nozzle, generally it's faster if I have turn the machine off myself.
The CT18DXQD in above posting has plastic rear wheels, straight nozzle design, slightly higher profile in rear. In servicing there is a separate nozzle area cover to be removed, after taking off top cover.
Pictured here is CenTec CT20DXQD. Rubber rear wheels, which according to some consumers, they've had experience with rear wheels coming off axle, lower profile from many other nozzles. Very bright headlight. You will notice it lighting up the cieling greatly. T shaped nozzles will fit around some chair legs and some other obstacles a little.
Many repair shops like both nozzles. I've heard some argue that the belt on Cen-Tecs is too narrow to really distribute power. My argument is of the suction dection. Overall cleaning performance is good on both, chevron agitator is good, but bristles aren't very long so I imagine they may wear quickly. Motors are very powerful and quiet, and built for many years of use.
Best of luck, let me know if there is anything else I can help with. Try plugging in the machine without hose connected, I'd be curious if it turns on or not. You can see what others or a vac shop may recommend but I wouldn't worry too much about cleaning the hose as I think you will need to replace it in-order for the machine to shut off.
http://www.centeccommercialvacuums.com/commercial-cleaning-items/CT20DXQD
Don't go & buy a new hose....
I will GUARANTEE you it's not the hose that's your problem here. The relay box inside the canister itself is failing here, that's what needs to be replaced. It is not a part that breaks often, they are very reliable....but when they do, the vacuum will not shut off by the handle switch.
If you call Sears Parts & Service, they can send you the part directly, & it's not that expensive- about $25 plus shipping. It is very easy to replace it yourself at home, if you know simple wiring & you can make a note or take a picture of how the wires were wired to the relay box & rewire the new one the same way. The Panasonic MC-CG902 vacuum mentioned above is IDENTICAL except for color, so a Panasonic relay from this model would also work, if you prefer to buy directly from a vac shop.
As far as the DirtSensor PN goes, yes the newer style & older style DirtSensor PN's, like the T shaped one above & yours, will fit your vacuum IF you get the one that uses the older-style wands. BUT you will also need to buy a new wand for it....the DirtSensor PN uses a different PN Neck, which requires a different wand to work properly. The one you have now will NOT attach to the DirtSensor PN, & will not work.
Hi Rob- Kirbylux77! Thank you for catching my error here, I didn't know about the relay box. That's good to know for the future.
Nice name, we're both Rob's!!
as a matter of fact both robs might be wrong
not to offend or anything but it could be possible I have serviced plenty of these in the past and may the relay be not the issue the wires in the handle of the hose have a tendency to come apart from one another. inside the handle there are 3 wires that separate from the wire clamps take a look and see before going the way of the relay. usually a continuity tester comes in handy as well to see if there is a break within the wires of the hose itself
hope this helps :)
mike
oops lol sorry I didn't catch that I would look to see if someone hard wired the machine. if that is the case then u should look at another control board, you can pick em up fairly cheap off of ebay or better yet find a donor machine at the landfill, garbage night or the local vacuum stores dumpster lol
I don't believe Sam's Progressive is from 2005. I think the last ones of that style were about 2004. In 2005 they came out with the second type that moved the filter door to the back and the Powermate Jr stored in a compartment on top. They also changed to the T shaped Powermate instead of the one like Sam's.
Rob, one small thing I noticed in what you said about the PN on the current vacuums. The PN on lime and orange canisters is very close to the ones on the white and blueberry Progressives. There is a slight difference though, as the lime and orange have the wheels on the side and the Progressives have them on the back. Also the reset button is square on the Progressive PN and round on the other two.
Sears seems to take the power nozzles from past generation Progressives and puts them on the lower end canisters when they change to a new model. The PN on Sam's Progressive for example, was later used on two lower end canisters, the guacamole and sky blue models from about 2005-2008.
If bagintheback is reading this, he would have the 2004 and earlier Kenmore Progressive models, because the 2005 and up models to him look hideous.
Picture off eBay of Kenmore Blueberry model 21614. Notice rear wheels are round with rubber coating. One on each end on rear of power nozzle. This is the same design on the lime, orange, blueberry and white. Cen-Tec power nozzle CT20DX. The motors, agitators and wheelbase design are exactly the same for each one.
For years Kenmore used the CT14DX on its upscale models and CT12DX on some lower end models. Later around 1997 Sears came out with the Progressive as seen in this thread with the CT18DX, then around 2005 they started using the CT20DX.
All of these power nozzles are still available and manufactured by Cen-Tec Systems. They can all be seen in various central vacuum system kits and under different names. Nutone used the CT14DX for several years as their CT600 powerhead, they also used a CT18DX with dirt sensor as their CT650.
The Panasonic MC-CG902, MCCG917 and MCCG983 all use CT18DX.
Granted over the years Cen-Tec has made little tweaks in some of these. Earliest editions of the CT14DX had 2 rows of replaceable brush strip and a beater bar, it also had a geared belt. Current edition of the CT14DX has the wooden chevron just like the other CT18DX and CT20DX and airflow channels have been added instead of a completely flat front lip to the agitator cavity. Early editions of the CT20DX had a motor shutoff protection which was easier to reset with a pen or other small implement as it was a thin recessed red plastic pin, and many of the CT20DX series have a round push button that is easier.
Close up pic
2006 Kenmore 25513 power nozzle, Cen-Tec model CT20DX. The base is a dark gray color compared to the Blueberry power nozzle which is an off white base. Also the older style had a slightly different agitator with little brush tufts extruding from raised plastic on the side around the belt. The newer design tends to be wood on that side of belt with longer tufts of softer brush.
There should be 4 screws that come out....2 right by the hinges on the bag cover, & the other 2 are hidden under the gray plastic cordwinder button. You will need to pry the cordwinder button off with a flat blade screwdriver. Once inside, the black relay box will be right between the cordwinder & the motor, & it is held in place with 2 screws. Take a picture BEFORE you take the relay out, as well as make notes of which color wires go where on the relay, so you know how to re-wire it correctly. While you are inside the motor compartment, make sure you remove the foam wrap filter on the motor & give it a good rinse....I guarantee you that by now, it will be filthy.
Best of luck with the repairs....Rob
