Hot Dyson plug?
vacuuman101
Vermont
So the other day I was vacuuming with my Dyson DC07 and by the time I was done I went over to unplug the vacuum from the wall,and I touched the plug and it was HOT!(and this has been a problem for about a month now). So felt the cord around the plug and it was very hot as well. So ageist my better judgement I found a cool part of the cord and puled it out of the wall. Then while I was winding it backup I felt the two prongs and they almost burned my finger. The vacuum has the original cord I will also post pictures of the vacuum and cord/plug.
(by the way my house was built in 1976 and the electrical is pretty good and the outlet was replaced in the last 10 years and it doesn't get used much.)
Jeremy,
Your plug-end is most likely failing. I have a DC14 and a DC28 and the 28's prongs got very hot and then the machine started cutting out completely. I could easily tell that one of the prongs had broken loose in the molded plug, so I replaced just the crappy aluminum molded plug end with a real copper pronged one. Cost me $1.75 and no more heat build up anywhere!
Bill
You say your house was built in 1976. Does it have aluminum wiring? It was all too common in that era. They quit using it because it was a fire hazard. The wiring would overheat just like your plug. The prescribed fix is to 'pigtail' the outlets with a few inches of copper wire to act as a heat sync. My house, built in 1970, has aluminum wiring and I had an ongoing problem with burnt wires on my furnace until I had an electrician pigtail the wires at the furnace and at the breaker. Better to fix it than have a house fire like my sister and her first husband did with a similar vintage house.
Does your Dyson plug heat up if you plug the machine into another outlet and run it?If so--you will need a new cord.If it heats up from the outlet-then your outlet or its wiring has problems.Then its time to see your electrician.
Thank you for all the replies, I'm not sure what my house has for wiring but we don't have tripped backers or burnt wires. But when I plug it in it will do the same in every outlet. But I will try to buy a replacement plug and see if that works.
Sounds like your wiring is probably okay, at least for the load the vacuum cleaner is pulling. I checked and it appears they quit using aluminum wiring after 1972. Replacement plugs are very inexpensive as Bill said. You can find them in any hardware store. Get one with a round hole for the cord and brass fittings and you'll be fine.
To day I went to lowes and bought a plug, I just need to get wire strippers to fix it.
Thanks for all the responses they really helped me!
